It would be really nice to have a master button to over-ride the "hidden" property of all objects on the currently selected layers...
Current method of using the select objects by name and finding them is irksome, especially with things in groups.
Regards
Trevor
Alterative method... have a special Layer named Hidden objects that ONLY shows hidden objects on all other layers.
Bearbeitet von trevor
It would also be nice if the select objects by name form was a tool window and not a dialog.
Currently you have to open it.. select something...  close it, change the visibility, and REPEAT ....
