Little problem with RocStudio.
I want to follow the occupation of the switches. To do this, I declared a detector with the same name as the switch, at startup, in manual mode, if I move the loco on the switch, the occupation is well recovered in RocRail. If I switch to automatic mode, the occupation does not go up again, even if I go back to manual mode ?
You will find here the solution that I adopted temporarily.
