MBS enables routes every reload. This causes problems.
If I create a layout may enable or disable routes. When I save and reload layout MBS ruins all settings re-enabling all routes. This is the same case when switch all turnouts to base position.
Please enable routes during creating (when select and move object from catalog to layout) and save current state later instead of re-enabling them.
If you aware of size problems then I recommend to record disabled routes only because there is a few of them in usual.
No way to correct this error by program because program do not know when layout is reloaded.
Thank you in advance!
I find it difficult to understand you, what do you mean by "enables routes"?
Are you using a translation tool like Deepl?
No, this is standard MBS function. Disabled routes vehicle can not drive into. Object.routes[1].active = false
Or - if locked turnouts are not outlined in simulation - I discard all this and shall use turnouts. This is an alternative solution.
Or - if you develop an event "layout loaded" then I shall use this to re-disable routes.
Do you have a small example which demonstrates the behavior? MBS reloads a layout in the same state as it was saved.
Use this layout:problem.mbp
1: Press button. Route is disabled, grayed like turnouts. You can check this with Bettina.
2: Save layout.
3: Load layout. Route is enabled! You also check this, Bettina walk away without problems.
Thank you for the sample layout. I understand what you mean, you disable the only route of a single track. Currently, route activations are meant for turnouts, not for single tracks, but I will have a look if this can be a valid behavior.
Thank you!
Multi-track routes has the same behaviour. I choosed this method because of simplicity and not outlines. These are not user-handled routes.
