I got tired of guessing numbers..... so threw together this quick calculator.
Enter the variables you care about and it figures out the others.
Once a variable is yellow (a user entered value).. simple select it and delete to clear it.
Good luck
T
Switch_Length_Calculator_20161210_0817.zip
Bearbeitet von trevor
Hi trevor,
When I try to enter a decimal point the cursor "jump" to the front of the value (left before) and the decimal point is cleared and if i now enter a number it will be set before the value and is been written right to left -> i try to enter 15.873 -> 87315 is shown...(same with a comma):(
Bearbeitet von EASY
