andrehetzel Geschrieben 30. September 2019 Geschrieben 30. September 2019 Pourriez vous me dire comment je copie une "Ereigniss" Merci d'avance André
EricD Geschrieben 5. Oktober 2019 Geschrieben 5. Oktober 2019 Sorry my French is not good enough to explain this. I hope English will do: To copy events from Layout2 into Layout1: 1. Load your Layout1 2. In Layout1 go to the menu "Edit" and choose "Paste From" then "Layout" 3. Select your Layout2 The entire Layout2 will appear next to Layout1. In the Events tree there is now an entry "Events (imported)" You can now delete Layout2 but this will affect any of the "Events (imported)" which refer to the deleted objects. Hope this helps!
