Leslie Geschrieben 1. Mai Geschrieben 1. Mai In case of computing "any vehicle" condition please always exclude current vehicle. It only affects conditions but actions and iterations remain unchanged. Maybe rename condition name to "any other wehicle". Thank you, in advance!
Goetz Geschrieben 1. Mai Geschrieben 1. Mai Hello Leslie, for clarification: You would like to detect if another vehicle or multiple vehicles is/are on the same track piece that your triggering vehicle entered? If so, the following script condition will do this for you: return #layout:getVehiclesOn(track) > 1 example layout: track occupied condition.mbp Kind regards Goetz
Leslie Geschrieben 1. Mai Autor Geschrieben 1. Mai Thank you, this works. But I wish use minimum LUA for this. I recommend to modify current command module (vehicle is located on track/contact). Currently this module uses boolean. Please, add a programmable number: "vehicle is located on track/contact > number" where number is zero by default. Thank you in advance!
