hmclay Geschrieben 9. Mai Geschrieben 9. Mai I locked a "Group" of virtual tracks and made then invisible . I locked them so I would not inadvertently move them. I now need to edit this group, but I cannot make them visible or unlock them. Is there a solution ?
Goetz Geschrieben 9. Mai Geschrieben 9. Mai vor 6 Stunden schrieb hmclay: Is there a solution ? Yes, you can always find the locked and invisible models in the structure view. You may even filter that view to show only invisible objects. Click on the magnifying glass in the bottom menu or press F3 to open the structure view. Kind regards Goetz
hmclay Geschrieben 12. Mai Autor Geschrieben 12. Mai Thanks Goetz for replying. When I requested help, nothing I did would unlock or make visible those items I had locked. Tried all sorts of things. Went on to work on other items, when back today, and no problems. Seems this happens at times, where something doesn't work or run correctly, reload the program after shutting down, and the code or function works "normal" again. Was good to hear it was possible, because I thought it was locked forever !!!
