Leslie Geschrieben 9. Mai Geschrieben 9. Mai At program always must start iteration when you wish to access any vehicles on route (and the trigger is not the vehicle). But most cases you need only first vehicle. Please modify current routines to get first vehicle at route. Like this: getVehiclesOn("place",firstonly(boolean)) Or: getVehicleOn() In module I suggest a markbox with label: "only first vehicle". As commands and conditions. With this developing become quite easier. Thank you in advance!
Goetz Geschrieben 9. Mai Geschrieben 9. Mai Switch to Lua, drop the iteration (you don't need it) and pick the first item from the list: local t = layout:getVehicleGroup(vehicle) t[1].couplers[1].enabled = false disables the rear coupler of the first vehicle of a train
Phrontistes Geschrieben 9. Mai Geschrieben 9. Mai (bearbeitet) And t[#t].couplers[0].enabled = false disables the front coupler of the last vehicle. And this local t=layout:getVehicleGroup(vehicle) -- First Vehicle t[1].couplers[0].enabled = t[1].couplers[0].connectedCoupler ~= nil t[1].couplers[1].enabled = t[1].couplers[1].connectedCoupler ~= nil if #t > 1 then -- Last vehicle t[#t].couplers[0].enabled = t[#t].couplers[0].connectedCoupler ~= nil t[#t].couplers[1].enabled = t[#t].couplers[1].connectedCoupler ~= nil end disables the couplers at the free ends of a vehicle group. Bearbeitet 9. Mai von Phrontistes typo
Leslie Geschrieben 9. Mai Autor Geschrieben 9. Mai Based on the advice of @Goetz the partial solution: Create a user-triggered event with parameter "Track": $("Events").variables["Truck"] = layout:getVehiclesOn(Track)[1] Then you find the first vehicle of given track on the module variable "Truck". Or nil if track is empty. You can use this event with any module or write it directly to LUA.
EASY Geschrieben 11. Mai Geschrieben 11. Mai Hi, Am 9.5.2025 um 23:03 schrieb Leslie: Based on the advice of Goetz the partial solution: Create a user-triggered event with parameter "Track": $("Events").variables["Truck"] = layout:getVehiclesOn(Track)[1] Then you find the first vehicle of given track on the module variable "Truck". Or nil if track is empty. You can use this event with any module or write it directly to LUA. Note: layout:getVehiclesOn() does not necessarily return the correct order of the vehicles within the train formation. layout:getVehicleGroup() returns the correct order... EASY
Phrontistes Geschrieben 11. Mai Geschrieben 11. Mai It's good that you pointed that out. I completely overlooked that @Leslie always uses getVehiclesOn instead of getVehicleGroup.
