Leslie Geschrieben 12. Mai Geschrieben 12. Mai Hello, after a long, random defer execution the event "any object variable changed" has not triggered. Variable changes, OK. Placing before defer same command triggers correctly. After defer trigger missing: What happened here?
EASY Geschrieben 14. Mai Geschrieben 14. Mai Hi, Am 12.5.2025 um 19:18 schrieb Leslie: What happened here? I cannot reproduce your problem. Can you post an example system where it does not work? EASY
Leslie Geschrieben 15. Mai Autor Geschrieben 15. Mai Here is the layout: busz-pu.mbp The event is "Enter park" and "Any obj var chg". If a vehicle has "Park = 1" variable then directed to and Enter park triggered in specific places.
EASY Geschrieben 15. Mai Geschrieben 15. Mai Hi, vor 1 Stunde schrieb Leslie: Here is the layout: sorry, this is not a suitable layout for finding bugs... this is a mess in which you have tried everything. You should try to approach problem solving with a little more structure. EASY
