Hello, @KÖNNYEN
rotary control / tacho has 2 errors:
- in deafult (300) variation only works correctly if max speed of vehicle also 300. If I select 100 for max, then controller shows this speed as 300, so real display is percent (%) not km/h.
- all other variations plus has an error: for example if I select variation 100, then it shows max at 1/3 speed. So if I select 100 for max and variation 100, then it shows 100 (max) at real speed 33 and above.
Can you correct this? This controller is the most perfect for shape.
Die maximal angezeigte Geschwindigkeit muss mit der eingestellten maximalen Geschwindigkeit übereinstimmen, dann stimmt die Anzeige ganz exakt.
Da muss nichts korrigiert werden.
The maximum speed displayed must match the maximum speed set, then the display will be exactly correct.
Nothing needs to be corrected.
This is a known issue that will be fixed in the next version. Currently, the speedometer display (in all variations) is only correct if the vehicle's top speed remains unchanged at 330 km/h. This has been discussed in detail here with the result here.
Thank you, waiting for!
