Hallo @220hotwheels ,
Gruß Hermann
4 minutes ago, HWB Berlin said:
Hello@220hotwheels ,
Greetings Hermann
Hi Hermann
Forgive my error, some elements of terminology are easily misunderstood when one is not familiar with this type of file sharing. Many thanks for clarifying I will experiment along the lines you have suggested. No doubt it will all become very clear as I move forward.
Many thanks
Pete
Hello @220hotwheels
The zip file contains an empty catalog.
Export the system and the elements that are not in the online catalog to a folder, change the catalog in the program, restart the program, and import the system and elements into this catalog.
Now you can share this catalog.
Hallo Pete,
in der zip befindet sich ein leerer Catalog.
die Anlage und die Elemente die nicht im Online Catalog sind in einen Ordner exportieren, im Programm den Catalog wechseln, Programm neustarten und die Anlage und Elemente in diesen Catalog importieren.
jetzt kannst du diesen Catalog weitergeben
Catalog - Kopie.zip
Bearbeitet von HWB Berlin
13 minutes ago, HWB Berlin said:
Hello @220hotwheels
Hello Pete,
There is an empty catalog in the zip.
Export the system and the elements that are not in the online catalog to a folder, change the catalog in the program, restart the program and import the system and elements into this catalog.
Catalog - Kopie.zip
Hi Hermann
You're a star, many thanks. I had got as far as creating a copy catalogue and simply naming it catalogue 1 but when I looked into the data folder I really hadn't a clue as to how to proceed. My first thought was to simply delete all of the data, load the program as normal and then try to save the layout in the new catalogue, but I could see potential problems by doing so. I had not thought to export the system into the new catalogue so yet another learning curve to add to the ever expanding knowledge base.
Many thanks
Kind regards
Pete
