Would be very helpful if you could add type 15 = Hidden Objects to command 100 in the plug-in interface.
Current state of the art is to interrogate everything individually, which takes forever.
  • 5 Wochen später...
Please change commands 50, and 51 to use values 0 = stop, 1 = normal, 2= x2 and 4 = x4 simulation rates instead of current Boolean value.
and add a new event..
Simulation_State_Changed returning state levels mentioned above.
Bearbeitet von trevor
  • 4 Wochen später...
We seem to be missing the ability to create and control a timer... we can read them but no set commands.
We really need events that occur when carriages connect and disconnect from each other.... something like
<event_code>;<State 0=Uncoupled,1=Coupled>;<Rolling-stock_ID_1><Rolling-Stock_ID_2>
Also need coupling state query command like this,,,
<Get Rolling Stock Connections command code><Rolling_Stock_ID>
<response_OK>;<front coupling connected to Rolling_Stock_ID or Null>;<rear coupling connected to Rolling_Stock_ID or Null>
<Get Train Stock command code>;<Rolling_Stock_ID>
<response_OK>;<Front Rolling-Stock ID>;<Next Rolling-Stock ID>;.................;<Last Rolling-Stock_ID>
It would also be helpful to have....
<Get Front of Train XYZ Coordinates> and <Get Rear of Train Coordinates>
154 Fetch current animation position...
String - Name of the object
string (optional) - Name of the animation. If not specified, all animations are returned.
Returns
string - Name of the animation. .
Floating Point -  position of the animation between 0 (zero) and 1 (end)
x Number of animations if name not requested in command.
Perhaps return -1 if the animation is moving instead of a position too..
(trying to control a swing bridge.. cant tell if its open or closed.... :( )
Sigh... Need Track Occupied Status command.
I thought I could use command 350 with the track name... but apparently that doesn't work and only returns true for whichever track the rolling-stock is centred on.
