EASY Geschrieben 24. Mai 2017 Geschrieben 24. Mai 2017 HI, ... You can use "Edit" -> "Paste From File"... or "Catalog" -> "3D Modell" -> "New" .... Note: if you use "Catalog" do not use "Publish to internet and share with oher people" if there is a copyright on the model... Note: The model must be in .x format and is only stored (in 3D TS) local on your computer (you can not share the 3D TS project). The texture(s) must be in the same directory as the model and must have a size of 2^x (i.e 1024x1024 ; 512x256...) EASY
ademes Geschrieben 10. Januar 2019 Geschrieben 10. Januar 2019 Hello, Happy new year to everybody, My question : after exporting event from one layout, is it possible to import it back to another layout? Thank you in advance for your help André
ademes Geschrieben 13. Januar 2019 Geschrieben 13. Januar 2019 Hi, Is there someone to answer to the questions, please?? Thank you André
