Would anyone be willing to create a covered hopper for me
Hi,
... do you have a picture or a sketch how it should look like ? ... how big ?
  • 1 Monat später...
I found some models but how do I tell if they will work
Hi,
 First, you can check whether the model in the 3D TS can be loaded...
"Edit" -> "Paste from" -> "File"
... the modell will be loaded in 3D TS at position x=50 ; y=-50 ; z=0
Note: The model is only loaded as a model... if it is a track vecicle it can not be used as a track vehicle (....it is a general model)
If you want to try a track vehicle you have to put it in the catalog...
"Catalog" -> "3D modells" -> "New" -> "Track vehicle"...
... "Settings" -> "Model" -> your model ->"Next"
... "Catalog Settings" -> "Category" -> "Extra" -> "Test" -> "Private"...
... in the catalog...
... you can find you model and try if its works correctly as a track vehicle...
Note: The Model must be in .x format and its texture(s) must have a size of 2^x (i.e. 1024 x 1024 ; 512 x 256 ...)
