ademes Geschrieben 21. Dezember 2017 Geschrieben 21. Dezember 2017 Hello, I already drow a more or less complex layout in CDM and I would be happy if it is possible to import an image 2D (BMP, JPG ) for each level in 3D tranStudio. Example fo level 5 : the hidden station to be implemented on the basic plate. Thank you for your help. Sorry, but I do not speak nor read german. Regards André
EASY Geschrieben 21. Dezember 2017 Geschrieben 21. Dezember 2017 Hi André, ... take "Ebene" from the catalog... ... size it in the same properties as your layout picture... ... texture it... ...you can lock "Ebene" so it only can be marked by a doubbleclick... ... this is the result... Regards EASY
ademes Geschrieben 22. Dezember 2017 Autor Geschrieben 22. Dezember 2017 Hi Easy Many thanks for your help... It works great. Regards
