If I take an area (circle) about 1000 mm radius and plant it full of trees, link them to the bottom plate then stretch the same circle into a cone shaped mountain, will the trees rise with the landscape?
Hi Curt,
no... the surface of the plate is only reference for a model while being set on it or the model is moved.
