Does it matter where custom textures and sounds are stored for a layout?   I have several subfolders for Backgrounds, Materials, Signs, etc.   If I shared a layout and included a link to the textures would the other person have to recreate my subfolders or just import them?
Hi Curt,
as for as i know, 3DTS works with references. For models, textures or sounds fron the catalog the reference is the content ID. If you use a texture or sound from a file it seems (for me) 3D TS use as reference the file path...
I saved my layout as an Mbp file, then moved some textures from My Textures to a subfolder within my textures.   I then closed 3DTS and loaded the MBP file.  It worked just fine with all the custom textures, so 3DTS must search all subfolders.
