Curt84328 Geschrieben 2. Juli 2019 Geschrieben 2. Juli 2019 can the < and > be used to compare a variable against a set value? as in variable is changed, the variable is 119Speed, and the value >0 which should check if the 119Speed shows that the locomotive it was set from is moving?
Andy Geschrieben 2. Juli 2019 Geschrieben 2. Juli 2019 no answer yet? tststs. Okay, the answer is Yes. Just don't use <= or >=.
