elveejay Geschrieben 22. Februar 2015 Geschrieben 22. Februar 2015 I've tried to see if I can somehow change the state of things like switches or signals...but so far without luck. Can that only be done in the paid version? If not, then how?Thanks in advanceLooking forward to playing with trains...yay!
FriLu Geschrieben 22. Februar 2015 Geschrieben 22. Februar 2015 Hello,Select signal or switch with the mouse (left button) and use the space bar to switch.Sorry, English is from Google - translater ...Many greetings, Lutz
elveejay Geschrieben 22. Februar 2015 Autor Geschrieben 22. Februar 2015 Thanks, Lutz - you just saved my day! :-)
stonem335 Geschrieben 27. Februar 2015 Geschrieben 27. Februar 2015 you can also add a switch and/or signal to the board and click the "connect" button in its settings to assign it to a pointalso in "event control", you can get it to switch automatically when a train passes through, reaches a certain part of the track or after a timer
