hmclay Geschrieben vor 19 Stunden Geschrieben vor 19 Stunden see attached file to see an example of a situation that has been recuring. without putting a defer execution command in front of these commands, they were not executed . occurs frequently in my coding. It's sometimes very difficult to know why a routine doesn't work, and the problem is generating quit a few lines of defer execution. anyone else experiencing this. Didn't seem to happen until I purchased a gaming computer, and now working on a new layout. Thinking the computer will be the suspected problem !
Goetz Geschrieben vor 14 Stunden Geschrieben vor 14 Stunden Hello @hmclay, you may safely remove these delays. They are inserted into the code when you convert a layout from pre V5 days. The purpose was to ensure that the proper order of events from the old event manager is maintained. Kind regards Goetz
Phrontistes Geschrieben vor 12 Stunden Geschrieben vor 12 Stunden (bearbeitet) vor 7 Stunden schrieb hmclay: attached file Why is there no difference between "if" and "else"? The else branch is superfluous. Actually, the whole procedure makes no sense. Bearbeitet vor 12 Stunden von Phrontistes
