nikfincher Geschrieben 15. August 2016 Geschrieben 15. August 2016 I would like to add crewmen to locomotives. A partiular issue with steam locomotives. Odd seeing them proceed unmanned. I have tried... ---Pausing. ---Placing 2 people models in the cab at correct height. ---Merging into a fixed group. ---Unpausing. But the train zooms off leaving the 2 people immobile 20mm above the track. Nik
Henry Geschrieben 15. August 2016 Geschrieben 15. August 2016 use the chain symbol in the properties window to connect an object to another object in the scene. select a crewman and place it on the locomotive, the crewman must be selected click on the chain click then on the locomotive start the locomotive - the crewman will follow. Henry crewman.mbp
