trevor Geschrieben 11. September 2016 Geschrieben 11. September 2016 The event "Variable Is Changed" looks for a value. How do I make it trip for ANY value. Or more specifically, if it is a text variable how do I make it trip if I don't care about the actual content of the variable at that point?
Curt84328 Geschrieben 11. September 2016 Geschrieben 11. September 2016 I'm not sure I understand the question. I will try to answer. Train enters track. > Set Variable (Train Present) to 1 / check variable (Variable is changed checks Train Present for value 1. result stop train (Other Track) train leaves track > Set variable (train present) to 0 / (same check as above) value 0 result, do not stop train (other track) (this is all done by the same check as above) It's simple Boolean Algebra. Hope this helps
Henry Geschrieben 11. September 2016 Geschrieben 11. September 2016 (bearbeitet) Hi folks, Please note - 'variable is changed' is an Event and not a condition or query in terms of a condition. It refers to a single specific value to trigger the specified actions under well-known conditions. Therefore, there can be no event that applies to ANY value. Event Conditions Actions bitte beachten - 'Variable wird geändert' ist ein Ereignis und nicht eine Bedingung oder Frage in Bezug auf eine Bedingung. Es bezieht sich auf einen einzelnen spezifischen Wert, um die angegebenen Aktionen unter wohlbekannten Bedingungen auszulösen. Deshalb kann es kein Ereignis geben, das für IRGENDEINEN Wert gilt. Regards, Grüße, Henry Bearbeitet 11. September 2016 von Henry something
trevor Geschrieben 12. September 2016 Autor Geschrieben 12. September 2016 Hi yes I do understand the specific value methodology of the function. However I am trying to code a more generic system so that I can reuse as much of it as possible. In my example, the calling event passes a track section name to a common handler function. I did create a work around that uses two variables instead. The variable changed handler then looks up the value from the original variable. It works fine, but seems overly complicated. For numeric values you can do this by setting the lookup value to <9999999 or some such, but there is no such trick with text values.
Goetz Geschrieben 12. September 2016 Geschrieben 12. September 2016 Am 11.09.2016 um 17:05 schrieb trevor: How do I make it trip for ANY value. By entering the variable's name in the field where the value is expected.
trevor Geschrieben 12. September 2016 Autor Geschrieben 12. September 2016 2 hours ago, Goetz said: By entering the variable's name in the field where the value is expected. ha nice work around
