henricjen Geschrieben 14. März 2018 Geschrieben 14. März 2018 (bearbeitet) Hi all, I am new to the simulator and would like to try to make a new track texture. But I can not find any downloadable graphics template I can work on. And I cant seem to find a way to download one from the online library and then replace it with a new image. Is the such a track texture template anywhere online? Or can I find a link in a PDF guide? Kind regards, henricjen Bearbeitet 14. März 2018 von henricjen -
henricjen Geschrieben 14. März 2018 Autor Geschrieben 14. März 2018 Ok, turns out you can export a texture template to the .dds format. And then open it in a graphics editor with a .dds import plugin ( I use Photoshop CC with a freeware .dds plugin) It opens as a 512x256x72 RGB 8 bit image. Then you can create a new texture with the right track and ballast graphics at the right positions and save it as a .jpg. This .jpg can then be imported as a track texture. Got to love reverse engineering
Roter Brummer Geschrieben 14. März 2018 Geschrieben 14. März 2018 Hello Henric,that's exactly how it works. With a little patience, for example, you can create a certain 3D effect. Best regardsBrummi
