IF you are making a trackside sign would you use a regular label or a custom texture and place it on a primitive?   a Label is easier, but a custom texture on a primitive can be made to look nicer, and seen from the other side, a label is simply backwards whereas a primitive is invisible.    Your opinion?
Bearbeitet von Curt84328
Hi Curt,
the problem with custom textures is:
if you want to make your project public, those textures will be missed and you can't make it public, or people will get question mark symbols instead.
You would have to make those textures public too, but then Neo has to confirm this. However, if you want to make any texture or model public, you have to write a message to Neo to become an uploader at all.
greetings
while that is true (that textures must be supplied, you can create a zip of them and put it on a file sharing site.  I already am using special textures, and plan to share privately
