Hi. I'm a newbe at this simulation and I do not understand how to put tunnels in my layout.
I would appreciate any help with this challenge.
Thanks
geejo
Hello @geejo,
what is your concrete problem?
To put the tunnel objects from the online catalog and to place them to the layout or to create the tunnel tubes through the mountain lansdcape?
You can find tubes and portals as well as complete tunnel models in the subdirectories of the catalog directory "Landscaping\Tunnes, Galleries".
To make holes into the landscape surface, please select the layout panel with double click and then click to the tunnel symbol on the top of the property window of the program. There, you can create and remove holes within the landscape surface after you have clicked to the corresponding button. Above these buttons, you can define some specific properties of the hole to be created.
For further information, please see the Wiki description for landscape creation.
Many greetings
