I am thinking of adding a picture to my layout.   It will be a diagram of the track layout as often see high up on the wall of a signal box.
Is it possible to add a .jpg for example?
vor einer Stunde schrieb georgeb:
Yes, George, that's doable.
The easiest may be that you select the object "Ebene" from the category "Online catalogie -> primitives" to your layout.
Now select the brush icon in the properties window of this object.
Select the folder icon at the end of the "texture" entry field.
Select "File"
Select your .jpg image from your picture foilder
Finally, adjust length and width of the "Ebene" object to match the aspect ratio of your image.
Kind regards
Goetz
Bearbeitet von Goetz
I will try that tomorrow.  I appreciate all the help you give to me and you do it so fast.  It is simple to follow.
Thanks again.
George & Merry Christmas
Thank you.  It is exactly what I require.
Merry Christmas to all.
George
