Hello can a true technician give me some help, or explanation. On my computer I have for the moment a FPS rate of 30, on a fresh empty layout in rest. That is not workable to do something in a busy layout. It then goes below the 20 or worse.  ( sometimes even a freezing of the studio ). Of course it must be something here at home. But where should I look ? I used the windows task management system, but nothing special there. I started another game with a need of FPS ( I cannot measure it there ), the game works fine. Back to the studio, again 30.
Mostly I have here a rate of  120 in the studio, in rest, around 80 in active layouts with a lot of traffic. So I have to wait until this happens...
Kind regards, Herman
Bearbeitet von Herman
Hello, waited an half hour and it's back to normal as it mostly does, just saying.
Nevertheless, if some specialist knows what can cause this effect. ( I'm not looking for changing the graphic settings of the studio, mostly it is ok )
graphic card
With a Windows PC, sometimes there's a Windows update going on in the background, and this can affect network response, or graphics handling, or other stuff, until the update is finished. If this only happens sporadically, it could be an explanation..?
Bei einem Windows-PC läuft manchmal ein Windows-Update im Hintergrund, und dies kann die Netzwerkreaktion, die Grafikverarbeitung oder andere Dinge beeinträchtigen, bis das Update abgeschlossen ist. Wenn das nur sporadisch passiert, könnte das eine Erklärung sein..?
Thank you Douglas. It could for sure disturb.  I checked then already: there was no update of windows, the virus scanner was not scanning. No apps where updating at that moment.  The same apps in the background on that moment as now. Very kind regards, Herman
screen 2055529623_frequentiebeeldscherm.jpg.9e3febe0b91539eff369768cfede1689.jpg
screen
Energy Saving mode in 3DMBS graphic setup is off?
If this is the only game with these problems:  Do u have separate setup for the game in NVIDIA 3D setup?
Hello @HaNNoveraNer ,
Yes off.
I have to check again, but I think yes, I told via the  NVIDIA  screen that this game should use this graphical processor in stead of the integrated one. ( * - even the MBS says that it is using this  processor )
Energy Saving mode
Maybe there is something to find here , that my laptop is saving energy in some cases ( battery mode --> saving energy ? ) . Have to check.
Really thanks for the answer, kind regards, Herman
clarification
I am not sure, but lastly u could install the Demo of 3DMBS V6 and try the rate without overwriting your V7 library.
Hello, to all interesting in this post.
  • I kept V6 and some of my layouts are still there.
  • Reason, If a V6 user should have remarks on my published layout, I can still correct it in V6, and some layouts I do not want to convert to V7.
Back to my question. The following test is always with a fresh empty layout.
For the moment (*) I have an ok FPS.   In V6 +/- 240  In V7 +/- 120   (* measured  several times, a single time V7 gave 158, all the others 120 )
Now strange :   If I go in battery mode in V6 +/- 240 but in V7 it immediate drops to +/- 60 half the rate.  ( in V7 on battery is 60 the maximum rate, it never got higher )
Yesterday I checked extra that my battery mode in windows is set to "best prestations".
For the reader : I always work in connection , not on battery.
Thank you @HaNNoveraNer for mentioning V6. The dropping ( on battery )  to 60 FPS in V7 is always there, never in V6.
Kind regards to all, Herman
typo
  • 3 Wochen später...
Hello to all. In this week I accepted the download and installation of Windows 11.  After x times of restart and several updates, Win11 was ok.
Good news for me, I did not expect it, but the FPS rates of V6 and V7 start both at 240  in rest. Behaves always normal, even in  very busy layouts. So no more problems of the low FPS that appeared sometimes ( working on current ).  I hope it will stay so.   Of course it is something here, but I wanted to share also a good news.
