I can change the train destination indicator (online catalog -> Browse-> Infrastructure -> rail traffic ->platforms)
in the events when a trackcontact is triggerd  with the next LUA lines:
local t= $("Eindhoven destination indicator")
  t.labels["Zuglauf"].text  = "geleen"
  t.labels["Zielbahnhof"].text  = "Sittard"
  t.labels["Abfahrtszeit"].text  =layout.time
Updating the scoreboard(modular) in the same map gives an error "attempt to index a nil value (field 'Zuglauf')"
local t4= $("Eindhoven(modular)2") !!
t4.labels["Zuglauf"].text  = "geleen"
setting the properties for both objects in the layout look so much simular , but in the the eventscreen i cann't access the fields of the scoreboard(modular)
somebody who nows the right syntaxis??
Thanks
Heinrich
vor 6 Stunden schrieb hb.resing:
Hello Heinrich,
The message "attempt to index a nil value" tells you that the particular object has no field named 'Zuglauf'.
The proper name of the textfield of this particular model is '03 Zuglauf'
Kind regards
Goetz
And it must also be called:
"Zielbahnhof" "04 Zugziel"
"01 Abfahrtszeit"
What I do not understand, however, is why the current time should be permanently entered for the departure time?
Bearbeitet von Roter Brummer
"01 Abfahrtszeit"
I was just testing . I am absolutly new to Lua and this game . Is it possible to create an array with  schedules for all stations?
So , I have a question also for you. I think you are de designer of this nice  object.  ?! why uses the train destination indicator  no numbers in the label , and the scoreboard (modular) numbers in the label ?   :) have a nice day
vor 1 Stunde schrieb Goetz:
Hello Heinrich,
Kind regards
Goetz
Indeed , I missed the 03 . My stupid fault. I didn't  write the full labelname.
The destination sign, the object with different station names that "moves out"....... can I also change the names ?
Thanks to both .
Greetz ,
Heinrich
