@seehund Hi
I am using several of your great model fire engines in my current layout, see attached screenshot. This layout is based on road traffic utilising right hand drive and whilst I realise that I need to compromise using many of the models in the catalogue which are currently only left hand drive this is a fact that can easily live with, although @SualokinKhas very kindly provided me with several right hand drive versions of his wonderful models.  Anyway I digress somewhat. The purpose for my message is to see if it would be possible for you to supply, I believe it is called "swap texture" for one of your fire engine models, the one mentioned above. I have managed to modify each of the others by using a text box below the front windscreen, as per screenshot, and to do the same for the number plates but I cannot do this for the WLF model so if there is any possibility of making the required change to this model as well that I would be most grateful.
Living in hope.
Kind regards
Pete
Hi @220hotwheels,
seehund passed away a long time ago. R.I.P
Schöne Grüße
SualokinK
37 minutes ago, SualokinK said:
Hi 220hotwheels,
Schöne Grüße
SualokinK
Hi Sualokink
So I believe from HWB Berlin. I had noted that the model along with several others was accepted into the catalogue in September of last year. I am a little curious, was fmkberlin and seehund one of the same as both seem to add items to the catalogue on the same day or was that just a coincidence?
Best regards
Pete
Hi @220hotwheels,
@fmkberlin and @seehund are not the same person.
If you double-click on the name, you can see when the user was last active in the forum.
For @seehund that was 4 June 2018.
The models have been in the catalogue for longer. The models were converted to the new lighting system and released on the same day in September.
Schöne Grüße
SualokinK
8 minutes ago, SualokinK said:
Hi 220hotwheels,
fmkberlin and seehund are not the same person.
For seehund that was 4 June 2018.
Schöne Grüße
SualokinK
Many thanks for the information. Once again I have learnt something today which will hopefully help me not to make the same mistake again.
Best regards
Pete
