Hello Everyone!
Is is possible to save EDITED tracks (NOT tracks created using 3D MODELS -> NEW -> TRACK.) ?
I set them outside the "Bodenplatte" and I use copy and paste to put them in my layout. The DEMO version at the time would not allow me to use 3D MODELS -> NEW -> TRACK ... that is why I used the EDIT command of existing tracks to "create" my N 55 tracks. I would love to save those edited tracks in my library/catalog but I don't know if that is possible now that I have bought the PRO version.
Many thanks !
Oliver
Virginia/USA
Hi Oliver,
select your single track and click on menu "Catalog - 3D models - New - [Your Track]" to add it to your catalog.
Kind regards,
Hi Oliver,
Mark your edited track (i named it "MyTrack")...
... then open in the topmenue "Catalog" -> "New" -> "3D modells" -> "Selection"...
... in the next window choose "Next"...
... in the next window you can change then "Name" and the "Discription" of your track...
and choose the "Category" where you want to save your track and "Save"
Note: You can not make a new categorie.
Kind regards,
Bearbeitet von EASY
Oh Neo and Easy, it worked !! Oh thank you so much !!! I LOVE 3DTS, Keep up the great work !
Oliver
Ohhh I can see that a NEW folder has been created in ATLAS !! (Spur N Code 55) . Does this mean that the tracks will be coming soon thanks to Henry ?! That is great upcoming news !!
Oliver
Virginia / USA
They are on the way :)  I must only compare the dimensions
regards, Henry
P.S #3.: Upload completed. Curved turnouts are now included at this state. Please report unusual differences in the track layout .
Bearbeitet von Henry
"Upload completed"..... I am not sure what you mean dear Henry because I cannot see anything in the folders in question. (beside the tracks I had edited myself the very first time I bought and used 3DTS and that I had saved). Do I need to do anything to see your uploads ?
Hi Oliver
you have nothing to do. Neo must release the tracks in the catalogue. Please be patient.
Henry
Thank you Henry. I didn't know the procedure that is why I was asking. I am patient no problem at all, and I want to thank you both very much.
Oliver
As I now have seen, the tracks have been released for online use in the catalogue.
:D Henry
Dear Henry: thank you  thank you  thank you  thank you  thank you  thank you  thank you :):)
