lys_knight Geschrieben 26. Juli 2016 Geschrieben 26. Juli 2016 1)It would be nice to have an off and on button to disable the Z rotation as very often when grabbing an object I grabbed this axis by mistake and sent it below the "Bodenplatte" 2) It would be nice to have a "append another -object- " button (like the tracks) for walls, fences, platforms, roads, overhead lines, etc... ) I don't know who is in charge of 3DTS but I want to say thank you for such a great program: it is worth every penny. Oliver Virginia, US
Henry Geschrieben 26. Juli 2016 Geschrieben 26. Juli 2016 vor 7 Stunden schrieb lys_knight: 2) It would be nice to have a "append another -object- " button (like the tracks) for walls, fences, platforms, roads, overhead lines, etc... ) you can try the following procedure to copy an object at the same position: select an Object use Alt + leftmousebutton-click pull the object from its position to a new one. Henry
lys_knight Geschrieben 27. Juli 2016 Autor Geschrieben 27. Juli 2016 Henry this is a very neat function ! Very handy. Thank you !! Oliver
trevor Geschrieben 24. September 2016 Geschrieben 24. September 2016 On 26/07/2016 at 9:24 AM, lys_knight said: 1)It would be nice to have an off and on button to disable the Z rotation as very often when grabbing an object I grabbed this axis by mistake and sent it below the "Bodenplatte" I had the same problem lys, now I turn off the gizmo (which it took me forever to figure what it was) and only turn it on when I need to rotate something.
