Hi
In version 3 i was able to import 3DS files, which I can't do anymore in version 4, only MBE files...How come? I work with sketchup and in that one you can't export an MBE file.
So how can I import now my 3DS files in version 4?
Thx
Hi Neo.
I tried this and it worked to make a .X file, but when i try to import in TS4 i get an error message saying ...
The model could not be loaded, it has an unsupported format.
What can be the problem? I tried with several models with which I had no problem before in TS3.
Thx again.
vor 20 Stunden schrieb Neo:
Hi,
the 3DS format is very old and has some flaws, why its support was removed in V4. You can use the DirectX exporter in sketchup to export to X files, which are supported by V4.
Kind regards,
And exactly where do you mention it in the release-Notes ?
3DS ist still being used alongside .OBJ and .DAE for transferring meshes between different CAD Programs
