Can anyone tell me how to use the Rad0 and Rad1 in Sketchup for letting the wheels turn under a train?
I am trying anything but I can't seem to make it work.
Thx
Hello raf.sonneville,
Rad0, Rad1 is intended for the animation of the bogies. To turn wheels you must use Radanim.
Many greetings
Wüstenfuchs
thx
but I want to turn the bogies which each consist of 4 wheels. so the bogies move along in a turn
Hello @raf.sonneville,
to make wheels able to roll along the track by rotation around the axle, you must make a "Sketchup group" consisting of the axle and the connected wheels. Give this group a name beginning with "Radanim" (in V3 (version 3) of the Train Studio) or beginning with "_Wheel" (in V4 of the Train Studio). If you have realized several groups (one group for each axle-wheel-combination), you must specify unique names (e.g. Radanim0, Radanim1, Radanim2, ... in V3 or _Wheel0, _Wheel1, _Wheel2, ... in V4).
If you want to realize animated bogies, you also must create a "Sketchup group" containing all parts belonging to the bogie. Especially, all wheels of the bogie (possibly grouped as Radanim... or _Wheel...) must be inside of this group. You can only specify exactly 2 bogie groups for an vehicle model. These groups must be named as "Rad0" and "Rad1" in V3 or as "_WheelSet0" and "_WheelSet1" in V4.
If a bogie should contain rotating wheels, you must create groups Radanim... (V3) or _Wheel.. (V4) groups and insert them into the corresponding Rad0/Rad1 (V3) or _WheelSet0/_WheelSet1 (V4) group (nesting of groups).
If you have designed your Sketchup model in this manner, you can export it to an x-file and then upload to the Train Studio without any further precautions.
Many greetings
Thx Bahnland. I will try it. :)
