Curt84328 Geschrieben 6. Juli 2019 Geschrieben 6. Juli 2019 Is there an object in MBS that can serve as a light source? I want to stick one inside a building so that the windows glow.
metallix Geschrieben 6. Juli 2019 Geschrieben 6. Juli 2019 (bearbeitet) Hi Curt Lichtspiele.mbp I did this experiment a wee while ago. Basically, it is cubes (planes might work as well) fitted in each pane section of a window, that are colourized (white-ish ..yellow-ish) and switched visible=lights on or invisible=lights off. But fortunately, many builders now incorporate switchable illumination in their models so the workaround of mine is merely for older models without lights when you want them to have lights. Cheers Tom Bearbeitet 6. Juli 2019 von metallix correction
Curt84328 Geschrieben 6. Juli 2019 Autor Geschrieben 6. Juli 2019 25 minutes ago, metallix said: Hi Curt Lichtspiele.mbp I did this experiment a wee while ago. Basically, it is cubes (planes might work as well) fitted in each pane section of a window, that are colourized (white-ish ..yellow-ish) and switched visible=lights on or invisible=lights off. But fortunately, many builders now incorporate switchable illumination in their models so the workaround of mine is merely for older models without lights when you want them to have lights. Cheers Tom That indeed does work as I am building a building entirely with cubes and planes. thanks Curtis
Curt84328 Geschrieben 7. Juli 2019 Autor Geschrieben 7. Juli 2019 Daytime, the light panel is turned on, but the windows are frosted same scene at night.
