Herman Geschrieben 4. Januar 2021 Geschrieben 4. Januar 2021 Hello everybody, Some help please . Can someone explain what this property exact does ? And if possible an example how to use it. Thanks, Kind regards, Herman
Goetz Geschrieben 4. Januar 2021 Geschrieben 4. Januar 2021 (bearbeitet) For train traffic, I can't think of a good use (yet) But for road traffic, it's a powerful new feature. Activate that option, if you want a car to follow the car in front. Say you stop a car at a traffic light: if the cars behind have the Minus option activeated (like on your screenshot), they will also stop and at a respectful distance. Now, when your traffic light changes and you set the car in front in motion, you may want the cars behind to follow. And that's what the Plus option is for. It's a bit tricky to use, because you'll need to turn it off and on, depending on the current situation. The first car at the traffic light must have it off, or else it will follow the cars crossing.# This is a fine example from Brummi: and here's a moce complex example layout: Content-ID 81A75E39-DCC6-4212-BB42-FDBEFDE15C36 Bearbeitet 4. Januar 2021 von Goetz
Herman Geschrieben 4. Januar 2021 Autor Geschrieben 4. Januar 2021 Hello, Thanks a lot. I' m learning again. I will certainly look at Roter Brummer's example. Greetings, Herman
Herman Geschrieben 4. Januar 2021 Autor Geschrieben 4. Januar 2021 25 minutes ago, Goetz said: For train traffic, I can't think of a good use (yet) But for road traffic, it's a powerful new feature. Activate that option, if you want a car to follow the car in front. Say you stop a car at a traffic light: if the cars behind have the Minus option activeated (like on your screenshot), they will also stop and at a respectful distance. Now, when your traffic light changes and you set the car in front in motion, you may want the cars behind to follow. And that's what the Plus option is for. It's a bit tricky to use, because you'll need to turn it off and on, depending on the current situation. The first car at the traffic light must have it off, or else it will follow the cars crossing.# This is a fine example from Brummi: and here's a moce complex example layout: Content-ID 81A75E39-DCC6-4212-BB42-FDBEFDE15C36 Hello, This ref. 81A75E39-DCC6-4212-BB42-FDBEFDE15C36 leads to nothing her at home. Something special ? If I search for it in the catalog, it jumps to the 3D Models, but the zone My 3D models is empty and I cannot use that zone it. ( or do not now how ) Probably a plugin is needed ? But for now, I'm not working with 3D models. ( ex. Blender ); only with the 3D Train studio. I can read the Mini-Exp. from Brummi. Greetings, Herman
Goetz Geschrieben 4. Januar 2021 Geschrieben 4. Januar 2021 (bearbeitet) vor 8 Minuten schrieb Herman: If I search for it in the catalog it's not a model ID It's the ID of a layout. Hence, you need to search for it on the starting page. Please, click on "Online Catalog", then enter the id in the input field at the top right Bearbeitet 4. Januar 2021 von Goetz screenshot added
Herman Geschrieben 4. Januar 2021 Autor Geschrieben 4. Januar 2021 Hello again, Thanks, Kind Regards, Herman
simonjackson1964 Geschrieben 4. Januar 2021 Geschrieben 4. Januar 2021 It's also useful for ships, passing through locks or under swing bridges...
Herman Geschrieben 8. Januar 2021 Autor Geschrieben 8. Januar 2021 Hello, Just for those that want to see a demonstration video from the 3D studio announcing new things in V6. WikiOverview of the new functions4. Distance control - convoys and autopilotKolonnenfahrt und Autopilot - 3D-Modellbahn Studio V6 Greetings, Herman
Herman Geschrieben 1. Februar 2021 Autor Geschrieben 1. Februar 2021 On 1/4/2021 at 1:13 PM, Goetz said: For train traffic, I can't think of a good use (yet) But for road traffic, it's a powerful new feature. Activate that option, if you want a car to follow the car in front. Say you stop a car at a traffic light: if the cars behind have the Minus option activeated (like on your screenshot), they will also stop and at a respectful distance. Now, when your traffic light changes and you set the car in front in motion, you may want the cars behind to follow. And that's what the Plus option is for. It's a bit tricky to use, because you'll need to turn it off and on, depending on the current situation. The first car at the traffic light must have it off, or else it will follow the cars crossing.# This is a fine example from Brummi: and here's a moce complex example layout: Content-ID 81A75E39-DCC6-4212-BB42-FDBEFDE15C36 @Goetz Thanks for sharing the layout 81A75E39-DCC6-4212-BB42-FDBEFDE15C36 , or Crossroads. It was a great help. And there are also impressive idea's to study : virtual garage and shadow station. Kind regards, Herman
