220hotwheels Geschrieben 19. August 2021 Geschrieben 19. August 2021 @hubert.visschedijk Hi hubert As promised I have put together a few photo's for you to consider. I fully understand there is no obligation on your part and even if you were to consider producing anything along these lines it is likely to be well into the future, so many, many thanks for even considering this request. Kind regards Pete
hubert.visschedijk Geschrieben 19. August 2021 Geschrieben 19. August 2021 (bearbeitet) vor 2 Stunden schrieb 220hotwheels: As promised I have put together a few photo's for you to consider. If i could i would... As i said, not for now... some other things i want to finish, others that i have to pick up again. And then research of diagrams etc... measurements.. Sometimes goes more time in looking for that then actually building the model. Logos and the real fonts etc can be a pain in the you know where also But nothing impossible ! Lots of polys there in the hull.... in the model it self perhaps. (not the dinkey toy boats ) With kind regards Bearbeitet 19. August 2021 von hubert.visschedijk
220hotwheels Geschrieben 20. August 2021 Autor Geschrieben 20. August 2021 Hi Hubert Once again many thanks for at least considering this for a potential future build. I fully understand that it is not a priority but just a small seed for possible future consideration. Kind regards Pete
