ger klunder Geschrieben 19. November 2021 Geschrieben 19. November 2021 Hello MBS builders. Great the new version 7, Top work. The last time, Goetz had made another report on road traffic without switches. TOP Goetz. I've been trying to build on this for quite some time now, but without success. I just can't get the bus to go to its stop. Have used Goetz's example and scaled it down to use as as example. Hope you MBS can help me with this. Yours sincerely. Ger sample.mbp
Goetz Geschrieben 19. November 2021 Geschrieben 19. November 2021 Hello Ger, in your scaled down version, the depots have multiple empty entries in their target list. Also, the special treatment of trailer vehicles isn't required here. Instead, you may use the same method to guide the buses into the bus stop. Here's your reduced layout with the required changes: sample with bus stop.mbp Both depots now have proper target lists. And "Auto verlässt ein Autohaus" now contains a condition which checks for a variable "Bus". Kind regards Goetz
simonjackson1964 Geschrieben 19. November 2021 Geschrieben 19. November 2021 Just a small point, but the bus still doesn't stop...
Goetz Geschrieben 19. November 2021 Geschrieben 19. November 2021 (bearbeitet) vor 47 Minuten schrieb simonjackson1964: the bus still doesn't stop... Well, of course it doesn't. Nor will it continue it's journey when you do stop it. Because you never set these events up. I only mended the path finding for you. Because that is what you asked for. One step at a time, Simon. What good would a fully functioning demo do, if you don't understand each aspect? Greets Goetz Bearbeitet 19. November 2021 von Goetz
ger klunder Geschrieben 20. November 2021 Autor Geschrieben 20. November 2021 Hello Goetz, Thank you for answer and sample. For me now the next step is that when the bus is stop that he continue it's journey when the road is free. Do you have a tip were I can learn more about how and what to program with MBS ? Greetz Ger
Goetz Geschrieben 20. November 2021 Geschrieben 20. November 2021 This forum is your best source, Ger You find lots of explanations here as well as links to some videos.
ger klunder Geschrieben 20. November 2021 Autor Geschrieben 20. November 2021 That true Goetz, I always look up how something is build when the uploaded a new one. Or look at some videos and than try it Question are you going to make a part 2 about road traffic without switches, because you did speak about in your last video? Again thank you for all your help Ger
Goetz Geschrieben 20. November 2021 Geschrieben 20. November 2021 vor 41 Minuten schrieb ger klunder: are you going to make a part 2 about road traffic without switches I want to, yes. But not at the moment. I have to be in the right mood to make these videos. Sorry for being such an unreliable contributor. I wish I could do better. Goetz
ger klunder Geschrieben 20. November 2021 Autor Geschrieben 20. November 2021 Hello Goetz, Great news, really looking forward to part 2. I think that you are a good contributor and me and more are happy that you take time to do it Ger
