I have two items for a little help please...
1) Can I add, say, 1 minute to the current time and use this result to make an event trigger at that time.   Complicated?  Train released from Depot.  Arrives at Signal at 14:27.  Need to notify user a train will arrive at 14:30.  Then release train into system at 14:30.
2) Can I display the system timers on a "TEXT" panel ?
Thanks in advance
George
vor 3 Stunden schrieb georgeb:
Yes George, you can.
And it's really easy too:
Insert the action "deferr execution" from the time control category at the appropriate place
Yes, you can do that too.
Kind regards
Goetz
Thanks for "defer execution" suggestion.  So obvious but .......
It was a TIMER I wish to display not the TIME.  Any ideas.:D
Thanks for all your help.  It makes my hobby so much easier to enjoy.
George
Hi George, Happy New Year!
I think this question was already answered?
I don't think it's possible to put the value of a timer onto a display in the layout. But if all you want to do is monitor it to make sure it's working, you can use the Event Analysis tool:
Add the timers to the list using the + symbol
The only reason I can think of to put a timer display into a layout is if you are releasing trains manually "against the clock"?
In this case, I have come up with a rather complex solution that works
Create two number variables, Mins and secs. Set each to your start values.
Create a timer that expires every second and restarts automatically. When it expires, if secs is 0, then if mins is 0, do whatever you want to do when the full timer expires. If secs is zero but mins is not, subtract 1 from mins and set secs to 59, otherwise subtract 1 from secs.
Create three labels: Label-M, Colon and Label-S. Colon, you set to ":", line all three up, and at the end of the the event add actions to set Label-M = Mins and Label-S = Secs.
It's not elegant, but it will do what you want
vor 5 Stunden schrieb georgeb:
I'm sorry, George.
I didn't pay enough attention.
There's no direct means by which you can read out the remaining time of a timer.
Simon already said so. And offered a solution too.
Personally, I would use two timers to achieve what you asked for.
One for the actual event. A second one (with a period of 1 second) for the countdown until the first timer has expired.
Here's an example:  7563B6DE-7D2C-43CC-BACF-01407F057322
Kind regards
Goetz
Thank you.  Best wishes
George
Sorry Simon - I missed your reply.  Brilliant.  Just the ticket.
George
What are these referencing please?
vor 4 Stunden schrieb georgeb:
I'm sorry, George - didn't realise that you cannot know this
The number is the content ID of the demo layout which I uploaded for you.
On the start page of the 3D train studio, select the online catalog.
Then transfer the Content ID into the search field at the top right:
Kind regards
Goetz
Bearbeitet von Goetz
typing errors corrected
This system never ceases to surprise me - like your knowledge.
Can I ask another??   When creating a User defined event, there is a reference to parameters at the top of the screen.  If I set a parameter, how do I include it in the User defined event??
Thank you again.
George
Hello George,
vor 52 Minuten schrieb georgeb:
When you create a user-defined event ...
... you'll typically want to call this event at another place.
Here is where you pass your specific information on to the parameters that you established in the event's description
Inside the user defined event, you can access the parameters via the "trigger" entry:
And if you're wondering where the name "trigger" comes from, here's the answer.   :D
Sorry, I couldn't resist ...
Kind regards
Goetz
I need to find a better couple of words that mean more than Thank You.  Greatly Appreciated.  George
Great TRIGGER link.(y)
vor 22 Minuten schrieb georgeb:
Great TRIGGER link.
I'm glad you liked it :)
And your "thank you" is more than enough.
