Herman Geschrieben 29. März 2022 Geschrieben 29. März 2022 (bearbeitet) Hello, only a small wish, but maybe difficult to implement, I dont know. Is it possible to give the error in the analyser for set vehicle target, if there is no route found to that target. When we do it manually we get :"No valid route found", as it should. The analyser let it go. Thanks for reading, kind regards, Herman Bearbeitet 29. März 2022 von Herman
Goetz Geschrieben 29. März 2022 Geschrieben 29. März 2022 vor 22 Minuten schrieb Herman: Is it possible to give the error in the analyser for set vehicle target With Lua, you may check, if a vehicle has a valid target vehicle.target = $("Destination Contact") if vehicle.target then $("Label").text = vehicle.target.name else $("Label").text = "fail" end if the attempt to set a target failed, the "target" property is empty and as such "false". kind regards Goetz
