220hotwheels
Aktuell
Liest ein Thema: A translation issue
Alle erstellten Inhalte von 220hotwheels
File size
Hi Andy Glad you like the layout. As you can see from some of the other posts the general advice is pretty much the same so I plan to finally follow said advice and set up a simple test layout to play around with EM. Cheers Pete
File size
Hi Tom It would seem that everyone has pretty much the same advice. Lose the Fairmont layout for now and set up a simple track layout for the purpose of getting to grips with EM. This I will now do. The biggest challenge in getting to grips with this problem, for me anyway, is understanding how things work. It's easy to work through the various screens and select different elements to see what they do but without fully understanding some of the more basic principals of the loco management operation you just keep fumbling in the dark so to speak. I have gone through the online manual many times and this just gets me more confused. Perhaps it's the translation that does not help which is why I opted for the "jump in with two feet" approach. Anyway your advice to date has been invaluable so many thanks for that. Cheers Pete
File size
Hi Goetz Many thanks for your advice. As you have noticed your not the first person to advise me to set up a test track so point taken I'll put aside the Fairmont layout for now and see how I get on with a simple oval. They say that ignorance is bliss but on this occasion it's a pain in the butt!! Cheers Pete
File size
Hi Tom Many thanks for the above. It all seems so simple to implement and the last part is the easiest and most logical. However I have come to the conclusion that I must be either thick, plain stupid or overthinking what you are suggesting. I have no problem locating each of the elements that you have shown and have spent four hours this evening trying various combinations to try to achieve the desired result, all to no avail. No matter what I try the loco will stop at the station but will not start again unless I revert back to my original instruction, which is of course self defeating. I'll have another go tomorrow night, perhaps with a clearer mind. Many thanks once again. Cheers Pete
File size
Hi Tom Since our last communication I have been busy following your suggestions, although I am not quite there with all of my flexibend replacements, but it becomes a bit mind blowing after a while so I have done a bit more on the scenery in an effort to add further interest. That said I concluded that as it's primarily a train layout I ought to at least try to get some trains moving, albeit on a very basic level. I therefore decided to start by getting one train to run on each of four tracks and whilst my efforts are quite simple I was quite happy at this stage with the results as I got each loco to stop, start and change speeds without having to rely on anything else. My next target was to get a second train running on just one of the tracks, D-T4, another steam train. Initially I thought it would be quite simple to just copy the instructions for BR 45-01 and simply alter the loco info for the new one. That simply didn't work as the speeds, stops etc became very erratic for both loco's. I have spent the equivalent of 30 odd hours trying different alternatives but have got no where so I removed the second loco and pondered further. I still don't know what the solution is so thought I might see if you would at least be willing to point me in the right direction with regard to this dilemma. No doubt in the fullness of time I will get to grips with the more sophisticated aspect of variables but for now simple is good. Cheers Pete Fairmont V5.mbp
File size
Hi Tom How right you are on both counts. I've already made a start having now sorted the turntable/engine shed area so I think I have got the hang of what needs to be done. Already my file size has come down. albeit by only a small amount but by the time I have sorted all of the track and roads I might well be at an acceptable and more workable level again. I must admit I hadn't realised you could edit and add track as you have shown so many thanks again for that. My plan is to complete a circular track at a time starting with what I deem to be track 1. As I complete each one I will rename every section with an abbreviated reference but one that is pertinent to that particular track so track 1 will get the abbreviation AT1-01 etc, track 2 will be BT2-01. Points and crossing will become AT1-P01 and level crossings AT1-LC01. So here goes my spare time for the next few weeks is now allocated and I look forward to the challenge. Cheers Pete
File size
Hi Tom or should that be Yoda!! I am pleased that I have got the layers thing right, now I'll have to get to grips with the track aspect. I've briefly looked over your recommendations which certainly make a lot of sense, albeit it will take me a bit of time to digest it fully and get into the rhythm of changes but it is brilliant to be given the starting point. If I may i'll let you know how I get on. Cheers Pete
File size
Hi Tom I hope it's just a case of my description has not been too clear regarding my efforts re: layers so I have taken the liberty to attach the latest efforts, albeit it I still have some work to do sorting some things out and improving on some of my latest scenery attempts. I hope I have got the layers thing right but if not then I am sure you will put me straight!!!! Thanks once again for your invaluable tuition. Cheers Pete Fairmont V5.mbp
File size
Hi Tom You amaze me. Is there anything you don't know? I have already gone through and followed your advice regarding the water, roads and layers but have been reluctant to do the same with the rail tracks until I had a better understanding of variables. I have tried, in vain I might add, to emulate the example that you gave me but each time I have been unable to produce the list of variables that you had, so for now I have been concentrating on scenery. As part of the layers produced I have made one for hidden trains which has removed all but 4, one on each of the four main lines. All I did was simply highlight the full train, lift it from the track and place it in that particular layer. By doing so I hoped to a) get to grips with variables without having to remove the basic programs that I had created, just in case I botch up and b) rationalise the tracks one by one. However until I master the basics of variables I will remain in a state of limbo. As for switching to invisible. I assume you mean highlight the 'eye' symbol at the right of each layer. If that is correct then I have already done that for each of the 11 layers not in use. Anyway thanks once again for the advice as I have said before the two feet first approach sometimes works but you can't beat the more realistic approach with the help of someone so knowledgeable. I am for ever in your debt. Many thanks. Cheers Pete
File size
Hi I am keen to understand how the file size works with 3D Train Studio so that I might adjust my current layout in order to reduce lag. Until now my system has coped but the file size is now over 2.9Gb and as I continue to "paint" the scenery it is beginning to slow. I have asked this question of the manufacturer (info@3d-modellbahn.com) but have not received any answer. I know my layout is big, 12000 x 5000 and there are many 3d elements on this but if I can understand how the file is made up then it might help me to modify things in order to finish with a smooth flowing layout. Where I struggle to understand the file size thing is as follows: If I select a new board of a size 6000 x 2500, put 10 pieces of track on that board and save it the file size is greater than my original layout. I have already taken advice from other members on another matter and received invaluable advice with regard to creating different layers in order to gain more "grunt" when working. I have spoken to my computer manufacturer to see if my graphics card/PSU need to be increased but have been told that the present one should cope easily. So I am left to ask all you knowledgeable techies out there if you can help me to understand this whole file size thing with 3D design. Cheers Pete
how to program road traffic stop/start at lights and rail barriers
Hi Tom That's absolutely brilliant, many thanks. It might take me a while to digest it all but once I have it sorted then I will be able to move on. It took me a little while to find my way, smoothly, around the layers scenario but now it is almost second nature. I have already started to fine tune some of the water, road layout as well as re:examining some of the rail track but my file size still hovers around 2750kb but doing the alterations is certainly easier without all the other clutter. I will try to leave you in peace for now. I don't plan to be too adventurous for now with EC. My brain won't cope with too complicated at the moment but in time I'm sure I'll get to grips with it. I really do enjoy producing the layout and keep fine tuning much of the scenery. Cheers Pete
Hi Tom Since our last communication I have spent my time creating layers as you suggested and checking round to turn off all animations that I can fined. Part of this operation highlighted that some track sections, mainly around crossing barriers, has jumped out of alignment I assume due to the conversion from V4 to V5. These are now sorted and so I turned my attention to your penultimate message in particular the bit about the new feature EC-protocol (the tab next to the EC one on the right) so that I could turn the other locos etc back on. Clearly I am not looking in the proper place as I seem unable to locate said tab, and you were bothered that as a total novice I might pick up variables with ease. At present I seem to have difficulty picking up the hammer, so to speak, let alone knocking in the nail!!! Dare I say that your screenshots have so far proved invaluable. Once I have solved this little mystery then I can get back to rationalising tracks, roads etc to try to reduce my file size for whilst everything seems to run fine on my PC if I have to transfer to my laptop then everything slows. Talking of speed I am once again a bit puzzled. When I first started with 3D Train Studio I saved each days work using the date as part of the name ie Fairmont100819.backup then the following day would be Fairmont110819.backup etc and each day the file sizes grew significantly until I was upto 41,000kb. Even then I had no issues with program lag. Now at 2,750kb lag is sometimes apparent as you found and I cannot explain this. Cheers Pete
Hi Tom Once again thanks for the advice. The chances of me picking up variables quickly is akin to doing a moon walk next week. A challenge, though keeps the mind active so bring it on is all I can say. All the best, I'll let you know how I get on even if it has resulted in using a very large hammer to my very expensive system!!! Cheers Pete
Hi Tom You're a star. Without your assistance and advice I think I would still be in the stone age part of this hobby. I had thought that I had turned off and reset all animated elements as I introduced them but clearly enthusiasm must have got the better of me during layout modification. I'll try to be more vigilant in the future. I have started to set up different layers the first element that I have chosen for this purpose is the roads, largely because they are larger and therefore more easily seen when selecting. Once they are done then I'll tackle the rail tracks. The water aspect is a bit easier to sort. I have experimented with one part replacing around 50 squares for just 1 and playing around with the baseboard prior to placing the new sheet. You're right about getting great effects by using different mediums under the water. I have only briefly looked at how you set up the LKW van. Once again how right you are about the use of variables, although I would never have got there without your help. In fact even now it's going to take me some time to digest just how to apply this example to everything else. I assume the track contacts are created by the events program or are these separate items to be selected and renamed from the on line catalogue. I must sound like a real numpty with some of the comments and questions that I ask. I had also noted that all other trains etc were on stop and pondered on how to restart them so once again many thanks for the heads up on that part. I'll keep you posted on my progress, if that's OK. Many thanks once again. Cheers Pete
Hi Tom Thanks for all your efforts and for the example of EC. My computer doesn't seem to have a problem handling things at present but I take your point about reducing as much as possible. Whilst I can see the effect of getting rid of so many blocks of water for one large item I don't see any relevance for either track or road. If for example I remove 10 standard section of track each of 1806 polys and replace it with a single length the that new length is simply 10 x 1806. The same seems to apply to roads but water is different so I can see the merit in that. Regarding the layers. I can see the merit in following your advice and will do so despite this being something of a monumental task which I assume will involve removing all rolling stock in order to accommodate this procedure but I cannot see how I can reduce the overall file size by much. Out of interest I renamed your file Fairmont V5 modified, had to realign several bits of track at numerous points and then saved the file and backed up the database using the new file name. The size of the saved file has now jumped to almost 5.5, double what it was which leaves me somewhat puzzled. Anyway I have plenty to keep me occupied for the next few weeks. I'll let you know how I get on. Cheers Pete
Hi Tom What can I say but ooops, I guess the jump in with both feet approach this time has it's drawbacks. Many thanks in advance for your guidance re the EC scenario but your further recommendations pose me with yet another question. I can create the different layers as you have suggested but at the moment I am at a loss as to the best way to isolate the various elements not required on a particular layer so that I am left with just the layer needed, ie just rail tracks, roads etc.I do keep referring back to the manual but struggle at times with the English translation and so just play around until I get it right or make a complete mess. No doubt the answer will be fairly obvious, once you know, a bit like the "export a file" question so if you could point this addled brain of mine in the right direction once again I would be most appreciative. Cheers Pete
Hi Tom Thanks for the comments and advice. I'll certainly look into every aspect of your recommendations. I have briefly looked at V5 events simply trying to set up the bus WCF 01 to depart from the ferry terminal to the bus stop at Fairmont station but so far I have got no where. Clearly using the knowledge from V4 isn't the answer. I'll do more experiments tomorrow along with looking at the water aspect. Thanks once again for your help. cheers Pete
Hi Tom Many thanks again for your advice. I have now downloaded and purchased the full version of V5 but have not had chance to look at it in any great detail. After doing so I will probably continue with V5 only using V4 for possible experiments, therefore any recommendations you can let me have to simplify my various operations will be greatly appreciated. As you will see I have only really touched the surface of event control and many of the aspects of my work so far need to be tweaked but then that's part of the enjoyment. If you got everything right straight away where is the fun in that! The bus operation is currently only partly worked out as I was hopeful that through the forum I might be able to produce a more professional system. Anyway I will be interested in your views. The relevant file is attached. Chers Pete 220hotwheels Fairmont layout.mbp
Hi Tom Let me get this straight then. V5 is the beta version. Do I simply click on the section for auto update to beta version to get the trial of V5 and by doing so do I affect my current layout in V4 or can I run both simultaneously. Also for the future will my V4 layout transfer to V5 once it has passed it's trial stage and I have upgraded or would I need to start all over with my current V4 layout. My present layout has thousands of items so far and I have really only just started. Admittedly much of my work now is fine tuning and finishing the scenery, as much of it is just "placed" roughly at present, but that will be at least another 500 hours work followed no doubt by much change as my experience and knowledge grows. I haven't had so much fun since starting my own businesses 45 years ago. Computers then were almost wind up toys. Are you suggesting that I export my main V4 layout as is for you to look over and offer your advice or just my test track layout, which I will complete later today. Cheers Pete
Hi Tom Thanks for your reply and the offer to take a look at my test track. The first attempt was a bit of a disaster so I am starting a new one but it did at least give me some thoughts for my main layout which is V4. Despite everyone's advice I am still at a loss as to how to use variables. No doubt in the fullness of time it will come to me so all of my "Events" are quite basic using either track or road sections to control events. My challenge at present is to get 4 buses operating between a bus station and ferry terminal. The basic instructions are not so difficult but the challenge lies in getting everything to gel with the trains. The big challenge is at a level crossing with 4 tracks used by 16 different trains all crossing at various times. So far I have applied the principal of stop each bus at a bus stop just before the crossing and then at the appropriate moment, when the last carriage of a train has passed and triggered the crossing gates to open that will start the coach from the bus stop. Whilst this set of events is still in it's infancy I realise there is much still to learn to ensure a smooth flow for each bus but given time I will sort it in much the same way I have with the various boats that operate on my lake that are tied to the bascule bridge operation. No doubt variables would make for a simpler events control which is why I posted my question on the forum, the medium of which I am a complete novice too so I hope all will bear with me if I seem a bit slow to understand some of the finer points of it's use. Over the next few days I will set up another test track and then attempt to export it, once I have found out how to do so!!!. I suppose I could always send my main layout this way but am a bit loath to embarrass my self with all you knowledgeable guys. Thanks once again for all your advice and offer to assist me. Cheers Pete
Hi Guys Many thanks for your advice. I'll try to sort my problem out using as much of your recommendations as I can follow. Thanks once again Cheers Pete
Thanks for the advice offered to my problem. Perhaps I am just being a bit thick and overlooking the obvious but having set up a test track oval with both road and rail I am still unable to figure out how to incorporate variables into my events. I have tried numerous alternatives but none seem to work. At the moment the only way I can get crossing barriers to function is by setting each train to trigger the animation when it is located on a particular track. I have set a variable of +1 to close and -1 to open in the variables list for the one crossing that I am using on the test track and tried alternative setting in both the event, condition and action sections however nothing seems to work so I am clearly not getting that part right. I think I need a more detailed bit of guidance to sort this please. I suppose it's a bit like flying really. The principal is pretty straight forward but to fly a modern jet needs a bit more guidance than it does for a single engine gypsy moth. thanks Pete
Hi I am relatively new to this type of 3D modelling and have so far sorted much that I needed through reading the manual translation and much trial and error. One thing that is so far eluding me is how to create events that will allow road vehicles to stop at traffic lights and barriers when necessary and then to restart once the barriers go up or the lights change. Getting the trains to open and close the barriers is pretty straight forward but I am finding it really difficult to get to grips with the English translation that I assume might point me in the direction of how to solve the above problem. Any tips that would start me off on this process would be greatly appreciated. I now realise that I have perhaps been a little too ambitious in terms of 1st layout size, 12000 x 5000 'N' gauge, having now put in around 450 hours of most enjoyable computer time with at least the same amount of time still required to complete this layout but I do not regret one second. A day without learning is a day lost but sometimes you just need a bit of help to move your learning curve up a notch. Many thanks in anticipation of some assistance. Pete
