badattitude77 Geschrieben 28. November 2015 Geschrieben 28. November 2015 How do I access layouts on my laptop that I have built and saved on my PC, but haven't published to the internet?
BahnLand Geschrieben 28. November 2015 Geschrieben 28. November 2015 Hello badattitide77,if you can use the TrainStudio on both computers, you can export your layout on the original computer to a mbp-file, and - after moving this to your 2nd computer, import it there. For exporting the layout, select "Save project as ..." in the menu, but then click to the Export-button (at the bottom left) instead of the Save-button. For importing the layout on the 2nd computer, select "My Projects" at the start page and then, select "import existing project" below the selection window.Many greetingsBahnLand
badattitude77 Geschrieben 28. November 2015 Autor Geschrieben 28. November 2015 Thank you BahnLand, I'll give that a try.
badattitude77 Geschrieben 28. November 2015 Autor Geschrieben 28. November 2015 That saved the layout to "My Documents". It appears the two computers have to be connected to one another, either through a LAN or a homegroup. I guess this means layouts that aren't published to the web are saved on the hard drive of the computer they were built on, not making them accessible from the internet when logging on from a second computer at a remote location.
Plutoli Geschrieben 29. November 2015 Geschrieben 29. November 2015 Hi badattitude77,you can change the storage location to an usb stick. This you can use on both computers.Or, the better way, you use a little NAS to store the database. Then you can access the layouts on both computers over the network. This works very great for me with three Computers.GreetingsPlutoli
badattitude77 Geschrieben 29. November 2015 Autor Geschrieben 29. November 2015 Thank you for the advice Plutoli. I'm a long haul truck driver. I use my PC at home, and a laptop on the road. I'll probably go with the usb stick idea. Thanks again for the idea.
