Help with automating wheels in Blender and .x file
I have made a model engine in Blender and exported it to .x
When I load it into 3D Train Studio, it sits above the rail by the height of the wheel flanges.
Also the speed of the wheels is a bit out, again probably due to things being based on the outside diameter of the wheel (flange), rather than the size of the tyre.
Is there somewhere in Blender that I can adjust figures?
Is there somewhere in 3D Train Studio that I can adjust figures?
Is there something else I can do to fix this problem?
Hello Richard,
for adjusting the correct height position of the vehicle on the rail see here:
The rotation velocity cannot be regulated and is adjusted by the train studio to "normal" wheel height. When you want to specify a specific rotation velocity, you must define a separate animation set. But how to do this with blender, other hobby colleagues must help you.
Many greetings
All working
Thanks for that
Richard
Hi Richard,
Zitat
vor 6 Stunden schrieb Richard T:
when you use "Radanim" the speed of rotation is calculated with a "standard" diameter 1 (regardless of the diameter in your model)...
... you can use "_AnimWheel" but you must figure out the "right" speed by playing with the animation length and fps in Blender and make a .anim file.
