I was trying to create a square panel (Rechtech) with the dimensions in mm of 3050 x 128.   it defaulted to 3050 x 130.    seems 130 is the smallest possible dimension.
Hello Curt,
the lowest possible grid is 10 mm. Therefore, you can only specify 10, 20, ,,,, 110, 120, 130, 140, ... as dimensions, but not 128.
Many greetings
Bearbeitet von BahnLand
130 works, so not a bug, but a feature.
Am 5.1.2019 um 07:10 schrieb Curt84328:
...... a feature.
Hi Curtis
If the dimensions of a "plank" are critical there is a way to make one:
downside is: you can't model it as landscape like a floor panel.
Cheers
Tom
1 hour ago, metallix said:
Hi Curtis
Cheers
Tom
Had not thought of using a primitive.  since you can paint a primitive with any texture, that would work, but maybe too much work as I already have what I wanted.
here is what I have done.  the long narrow strips form walls
Untitled.thumb.jpg.09a18f1071ec872c0af4a7b0f5c6e60c.jpg2Untitled.thumb.jpg.12a01a0927c41ca208d124188a95ea1e.jpg2Untitled.thumb.jpg.12a01a0927c41ca208d124188a95ea1e.jpg
Ebene turns out to be one sided, texture only shows on one side.  will try the cube (quader)
