Curt84328 Geschrieben 16. Juni 2019 Geschrieben 16. Juni 2019 I am building a large complex model of a large building in MBS and was wondering, if I select everything, group it, and import it, will it pick up the custom textures I used?
Curt84328 Geschrieben 16. Juni 2019 Autor Geschrieben 16. Juni 2019 Here are some pictures the stone columns are from a fence, the beams are quaders that were sized and use a custom texture roof is quaders wall panels and doors added areas with green stars are custom texture. will the custom texture go with importing it as a 3d model?
metallix Geschrieben 17. Juni 2019 Geschrieben 17. Juni 2019 Hi Curt You will have to post the textures here or at least to post a link from where to download them. Otherwise a user without the original textures will just see ???? . Cheers Tom
Curt84328 Geschrieben 17. Juni 2019 Autor Geschrieben 17. Juni 2019 1 hour ago, metallix said: Hi Curt You will have to post the textures here or at least to post a link from where to download them. Otherwise a user without the original textures will just see ???? . Cheers Tom good to know. thanks
David Teide Geschrieben 2. Juni 2020 Geschrieben 2. Juni 2020 Du machst einen guten Job. Ich freue mich darauf, mein Problem zu lösen, nicht zu wissen, wie man die Texturen in den Simulator lädt.! ----------------------------------- Esta usted haciendo un gran trabajo. ¡Qué ganas tengo de poder solucionar mi problema de no saber cargar las texturas en simulador.!
