Hi
I have made my base board larger to add some extra track.
I now find that any track I try to add will not connect either with new pieces or to the old.
Any ideas please.
Thanks
Eric
vor 44 Minuten schrieb Eric Lord:
Any ideas please.
  1. it is not caused by the enlarged base board!
  2. it may be that you disabled the "auto connect" feature in the top menu:
Thanks yet again Goetz, I will have a look at the setting.
Hi,
No, it's not the auto-connect setting its still coloured blue.
Things were fine until the board resize, I have now reversed the resizing but that has not corrected the problem.
Is there a limit on the number of track pieces?
Eric
vor 2 Minuten schrieb Eric Lord:
Not to my knowledge, no.
But without seeing your layout (or watching you while you attempt to connect the next piece), I can't say what's causing your problems.
Hi Goetz,
I just drag the next piece of track to the red end of one piece but both ends stay red.
What do you need to see my layout, if it's my login details then I don't mind sending you them?
Eric
Actually, according to the home page, the free version has a limit of 150 objects, so if you're using the free version that could be it....  £42.97 (€49.90) is actually worth the price in my opinion!
If you aren't using the free version, then I am not sure, but when you say the "red end", on my version the active ends of splines are blue...?
vor 5 Minuten schrieb simonjackson1964:
when you save the layout. But you can build to your hearts content even with the free standard version.
vor 2 Stunden schrieb Eric Lord:
From the save menu, choose "save and share ..."
Checkmark the "upload as draft" box, so it doesn't count as one of your public layouts.
Drafts are automaticalkly deleted from the public server (but not locally!) after 30 days
copy the Content ID of your layout and post it here (or send it to me in a private message)
Cheers
Goetz
P.S.: Never share your personal details with anyone, regardless how trustworthy he may appear!
Besides all the obvious reasons, you'll put that person under undesireable suspicion, when something goes wrong with your account.
Because "it can only be him - no one else has access ..."
Thanks for your reply, Simon.
Yes, on the track which I get from the online catalogue when I try to connect is blue its the red bars which are at the ends like when it's a track at the end of a siding or station terminus.
I am using the paid version.
Eric
Ohhh, right. I seem to remember just seeing that limit and just paying for the full version (4.0).
Hmm... I would be interested to see this, because I can't make my layouts put red bars at the ends of the tracks... I can connect tracks to the "wrong" ends of buffer stops...
Maybe take a screen-shot and upload it?
Goetz,
As well as the board area being made larger I also made the thickness slightly thicker, perhaps this is the trouble.
I that's the case then I have a problem as I don't remember what the original thickness was.
I have just pulled two pieces of track out of the online catalogue and connected them with no problem, which makes me think that it's a thickness issue.
Eric
vor 19 Minuten schrieb Eric Lord:
I don't think so
Neither the enlargement, nor the changed thickness affects the connection of two elements.
If only I could take a look and wasn't forced to guess wildly - alas ...
I have just pulled two pieces of track out of the online catalogue and connected them with no problem, which ...
... makes me think, that the two pieces which refuse to connect, don't sit at the same height and you don't see it, because you neglect to check the 3D image of your layout.  But as I stated, I can only guess.
Bearbeitet von Goetz
Goetz,
I have just tried something.
I have put the layout in 2d mode got a new piece of track and yes it's at a different high from the track.
The new price slides under the layout track, so this means that I need to lower the layout track or bring the board  surface up to layout track hight somehow.
Eric
vor 5 Minuten schrieb Eric Lord:
at last, we found what's causing it.
I'd bring the surface up if I were you.
In 3D mode, double click the surface, hold the blue arrow (Z-axis) from the gismo and drag it up until satisfied.
Alternatively, select a piece of track, then on the properties menu select the "position" tab (with the little x-y-z icon). Copy the content of the z position, then select the baseboard. Paste the value into the z position field. This will ensure your baseboard is at the same height as the track.
I would like to say a big thank you to both Goetz and simonjackson1964 for all there help today.
In the end, I used the method which Goetz said to try.
Thanks again both.
Eric
 I only got involved because I was curious...!
bitte sagt mir immer, welches Gleissystem ihr verwendet !
Es kann nämlich sein, das in früheren Versionen zusammengesetzte Gleise als Gruppe in den Online-Katalog aufgenommen wurden. Es kann also sein, daß ein früher gruppiertes Gleis nicht mehr an ein Gleis aus dem aktuellen Katalog andocken will. In diesem Fall muß die Gleisgruppe vorher aufgelöst werden.
please always tell me which track system you use !
It may be that in earlier versions tracks that were grouped together were included as a group in the online catalogue. So it is possible that a previously grouped track no longer wants to dock with a track from the current catalogue. In this case, the track group must be dissolved beforehand.
Regards, Henry
