Hello,
Maybe a more special question, but here we go.
Just to see if I have a good understanding wich t comes out here :
local t = layout:getVehiclesOn(signal)  gives a table  t with the vehicles on that track contact. ( 1 item or none )
local t = layout:getVehiclesOn($("LongTrack")) gives a table t with the vehicles on that track
I want to know if there is a vehicle an the contact of the signal.
In previous tests I used # for the number of items in a table.
  if #t ~= 0 then  ( there is a vehicle on the signal , a wagon or a loc )
So far so good, my problem is solved.
But t is a table, the test
if t ~= {}  an empty table  failed, why  ?
Some help is welcome.
Kind regards,
Herman
Those are only references to tables.
You are comparing two different references.
You could check the NEXT Operator for that. But i am not sure that works. Remember there are different kinds of members in a table.
Hello @HaNNoveraNer
You  "Those are only references to tables".
A reference to the memory ( like a pointer ) I agree with you.
Thanks for your answer !
Greetings, have a nice weekend.
Herman (BE)
vor 7 Minuten schrieb Herman:
like a pointer
exactly.
t and {} are two different tables.
You want to know, if both have the same property (i.e. the same number of entries),
but with t == {} you're asking if both are the same table.
Hello Götz and Thomas,
With "only references to" from Thomas I understood that I was comparing two different things.
Thanks to both !
Nice regards,
Herman
