Alle erstellten Inhalte von ademes
build a TCO
Hello everybody (German follows) I think it's now time to explain what I'm trying to build. Please have a look at the simple layout below. The objectif is to create a 'TCO' as being exactly the same as the normal layout (tracks, switches,signals, engines, railcars, etc...), but at a very small scale. In the layout, the scale of the 'TCO' is 20%. First, do you think that this way to create a 'TCO' is a good idea? This should permit to the user to have a view on the whole layout, inclusive trains and rail & freight cars that are not visible on the normal layout (hidden station, for example). But I don't want to duplicate events and controls. It would be great to have controls and events applying on the 'TCO' layout having as result to manage at the same time the original layout switches, signals, stop, breaks,etc... and also the speed for the engines. For this reason, I search a easy way to "connect" switches between the TCO and the real layout. Thanks to Metallix, Curt84328 and Bahnland for the help they already give to me, but the proposed solutions are difficult to apply in this project. Please notice that linking the 2 engines is not a solution; the only way is to apply the same percentage to the speed on the small engines. For example, we have a 20% TCO and, so, the speed of the small engine must be 20% of the speed of its corresponding engine on the original layout (80 ==> 16). How to adapt it is also a problem if I do not want to set some additional actions in events. So, all your ideas and solutions will be welcomed. I thank you very much in advance for your help Best regards Hallo alle zusammen Ich denke, es ist jetzt an der Zeit zu erklären, was ich zu bauen versuche. Bitte sehen Sie sich das einfache Layout an. Das Ziel ist, ein TCO zu erstellen, das genau dem normalen Layout (Gleise, Weichen, Signale, Motoren, Triebwagen usw.) entspricht, jedoch in einem sehr kleinen Maßstab. Im Layout beträgt die Skalierung der 'TCO' 20%. Denken Sie zuerst, dass dieser Weg, eine "TCO" zu erstellen, eine gute Idee ist? Dies sollte es dem Benutzer ermöglichen, einen Überblick über die gesamte Anlage zu erhalten, einschließlich der Züge und Eisenbahn- und Güterwagen, die auf der normalen Anlage nicht sichtbar sind (z. B. eine versteckte Station). Ich möchte jedoch keine Ereignisse und Steuerelemente kopieren. Es wäre großartig, wenn Steuerelemente und Ereignisse auf das 'TCO' -Layout angewendet werden, um gleichzeitig das ursprüngliche Layout umzuschalten, Signale, Stopps, Pausen usw. und auch die Geschwindigkeit der Motoren zu steuern. Aus diesem Grund suche ich eine einfache Möglichkeit, Schalter zwischen dem TCO und dem realen Layout zu "verbinden". Dank Metallix, Curt84328 und Bahnland für die Hilfe, die sie mir bereits geben, aber die vorgeschlagenen Lösungen sind in diesem Projekt schwer umzusetzen. Bitte beachten Sie, dass die Verknüpfung der beiden Engines keine Lösung ist. Die einzige Möglichkeit besteht darin, denselben Prozentsatz auf die Drehzahl der kleinen Motoren anzuwenden. Zum Beispiel haben wir eine TCO von 20%, und daher muss die Geschwindigkeit des kleinen Motors 20% der Geschwindigkeit des entsprechenden Motors im ursprünglichen Layout betragen (80 ==> 16). Wie man es anpasst, ist auch ein Problem, wenn ich nicht zusätzliche Aktionen in Ereignissen festlegen möchte. Daher werden alle Ihre Ideen und Lösungen begrüßt. Ich danke Ihnen schon im Voraus für Ihre Hilfe Freundliche Grüße André Test TCO.mbp
Connect to more objects
Hello everybody (German follows) Many thanks for all explanations and help you provided to me. I think it's now time to ewplain what I'm trying to build. Please have a look at the simple layout below. The objectif is to create a 'TCO' as being exactly the same as the normal layout, but at a very small scale. In the layout, the scale of the 'TCO' is 20%. First, do you think that this way to create a 'TCO' is a good idea? This should permit to the user to have a view on the whole layout, inclusive trains and rail & freight cars. But, and you now will understand my obsession to pilote more switches with only one control buttom, I don't want to duplicate events and controls. It would be great to have controls and events applying on the 'TCO' layout having as result to manage at the same time the original layout switches, signals, stop, breake,etc... and also the speed for the engines. Please notice that linking the 2 engines is not a solution; the only way is to apply the same percentage to the speed on the small engines. For example, we have a 20% TCO and, so, the speed of the small engine must be 20% of the speed of its corresponding engine on the original layout (80 ==> 16). How to adapt it is also a problem if I do not want to set some actions in events. So, all your ideas and solutions will be welcomed. I thank you very much in advance for your help Best regards Hallo alle zusammen Vielen Dank für alle Erklärungen und Hilfe, die Sie mir zur Verfügung gestellt haben. Ich denke, es ist jetzt an der Zeit zu erklären, was ich zu bauen versuche. Bitte sehen Sie sich das einfache Layout an. Das Ziel ist, ein TCO zu erstellen, das genau dem normalen Layout entspricht, jedoch in einem sehr kleinen Maßstab. Im Layout beträgt die Skalierung der 'TCO' 20%. Denken Sie zuerst, dass dieser Weg, eine "TCO" zu erstellen, eine gute Idee ist? Dies sollte es dem Benutzer ermöglichen, einen Überblick über die gesamte Anlage einschließlich der Züge und Eisenbahn- und Güterwagen zu haben. Aber, und Sie werden jetzt meine Besessenheit verstehen, mehr Schalter mit nur einem Steuerelement zu steuern. Ich möchte keine Ereignisse und Steuerelemente duplizieren. Es wäre großartig, wenn Steuerelemente und Ereignisse auf das 'TCO' -Layout angewendet werden, um gleichzeitig das ursprüngliche Layout umzuschalten, Signale, Stopps, Pausen usw. und auch die Geschwindigkeit der Motoren zu steuern. Bitte beachten Sie, dass die Verknüpfung der beiden Engines keine Lösung ist. Die einzige Möglichkeit besteht darin, denselben Prozentsatz auf die Drehzahl der kleinen Motoren anzuwenden. Zum Beispiel haben wir eine TCO von 20%, und daher muss die Geschwindigkeit des kleinen Motors 20% der Geschwindigkeit des entsprechenden Motors im ursprünglichen Layout betragen (80 ==> 16). Wie man es anpasst, ist auch ein Problem, wenn ich keine Aktionen in Ereignissen festlegen möchte. Daher werden alle Ihre Ideen und Lösungen begrüßt. Ich danke Ihnen schon im Voraus für Ihre Hilfe Mit bestem Gruß André Test TCO.mbp
Hallo Vielen Dank für Ihre Hilfe, aber ich sehe nicht, wie Sie Ihre Lösungen anwenden können. Bitte beachten Sie das folgende Layout. Die Frage ist im Text enthalten. Danke André
Hello (german follows) Thank you for your help, but I don't see how to apply your solutions. Please consider the layout below. The question is contained in the text. Thanks André multiple switches control.mbp
Hello Metallix Thank you for your answer, but this will not help me as I want to execute the switching WITHOUT programming this inside an event. Imagine a TCO actionned by a serie of buttons. When I turn the button linked to a switch on the TCO, I hope also to turn the related switch on the layout too. I hope this is possible. Vielen Dank für Ihre Antwort, aber das wird mir nicht helfen, da ich die Umschaltung OHNE Programmierung innerhalb eines Ereignisses ausführen möchte. Stellen Sie sich eine TCO-Aktion vor, die von einer Reihe von Schaltflächen ausgeführt wird. Wenn ich den an einem Schalter angebrachten Schalter auf der TCO drehe, hoffe ich, auch den entsprechenden Schalter auf dem Layout zu drehen. Ich hoffe das ist möglich.
Hello, I would like to connect a control object to more than one other objets. Fo example, I would change the direction of different switches with ONE clic on one control at the same time. Is this possible? Thank you André _______________________________________________________________________________________________________________________________________________ Hallo, (atomatic translate) Ich möchte ein Kontrollobjekt mit mehr als einem anderen Objekt verbinden. Zum Beispiel würde ich die Richtung der verschiedenen Schalter mit EINEM Klick auf eine Steuerung gleichzeitig ändern. Ist das möglich? Vielen Dank André
plugin to CDM-Rail
Hi Neo, May I ask you to answer to the former question, please. Thank you André
import
Hi, Is there someone to answer to the questions, please?? Thank you André
import
Hello, Happy new year to everybody, My question : after exporting event from one layout, is it possible to import it back to another layout? Thank you in advance for your help André
plugin to CDM-Rail
Hello Neo, Happy new year. I've read a lot of documentation at both sides (mean 3DTS & CDM-Rail) and I cannot see the way to build a bridge between the two. However, you do it well with RocRail. Do you think that it would be possible to get the link to the sources of this plugin or is it copyright. Thank you anyway for your help. André
plugin to CDM-Rail
Hi Neo, 1. Where can I find a sample of a plugin? 2. In what langage must it be written? 3. To answer to your question, CDM-Rail has a "communication protocol" communicating via IP; is this ok to communicate with 3D? Regards André
plugin to CDM-Rail
Hello, CDM-Rail acts as a 2D track planner having the final purpose to drive a real layout. The plugin I would like to build should be an interface between CDM-Rail and 3D train studio exactly as the Rocstudio works as an interface between Rocrail & 3D train studio. In other words, this plugin should be able to translate the incoming instructions from CDM-Rail into events and orders in 3D train studio. CDM-Rail will probably consider 3D train studio as a real layout and will manage it. Thank you for your help André
plugin to CDM-Rail
Hallo, hier ist die Übersetzung (von Google) für Sie Hallo, Ich habe einige Fragen zum Erstellen eines neuen Plugins für CDM-Rail: 1. Ist es möglich? 2. Ist das akzeptabel? 3. Wenn ja, was sind die Voraussetzungen für die Erstellung? 4. Wer kann / darf es erstellen? 5. Was sollte von der Bot-Seite bekannt sein: 3D Train Studio & CDM-Rail? Vielen Dank für Ihre Rückkehr und Ihre Hilfe Grüße André
plugin to CDM-Rail
Hello, I have some questions about creating a new plugin to CDM-Rail : 1. Is-it possible ? 2. Is it acceptable ? 3. When yes, what are the requirements to create it ? 4. Who is able/authorized to create it ? 5. What should be known by bot side : 3D train studio & CDM-Rail ? Thank you for your returns and your help Regards André
MBS-Controller : Official Forum Page
Hello Kees Happy that you may go further. Please let me know your progress because, up to now, I encountered some difficulties with the route planner. Regards André
- MBS-Controller : Official Forum Page
Finally, the correct path to the templates is http://www.aaadbs.com/mbs_controller/#templates.zip André- MBS-Controller : Official Forum Page
Sorry, the link to the templates in my previous post does not work. Instead, from the document "3D Train Studio™MBS_Controller Plug-In Home Page" click on "TIMER TEMPLATE" and then on "Template" Under the picture. You will be directed to the correct place to select your Template. Regards André- MBS-Controller : Official Forum Page
Hello, I finaly foud a method for loading the appropriate Template. Do the following : search the templates for your scale at the following adress : http://www.aaadbs.com/mbs_controller/Templates.zip open the Template you need for your scale, for example MBS_Controller_Template_N.mbp for scale N save this Template into your layout directory using the "save as" buttom and give it the name you want open your own layout that you plan to translate to MBS controller Press "Past from + Layout" from the edit menu, select the template's name you just saved. Press enter The Template is now part of your layout. Hopping this may help. André- retreive my layout
Hello, The problem is elsewhere. When I said "I never save it"I mean I never save it to the community! But, in fact, each time before closing the application, I saved my project using the "SAVE" buttom. BUT I discovered that installing the 3D software from scratch after a "clean Windows installation makes the saved projects unavaillable to the new 3D application. It seems that in this case, I'm considered as a NEW user instead of a old one restarting from a new 3D installation. If i'm right, please tell me how to get my projects back.- retreive my layout
Hello, About 2 weeks ago, I was quite finishing the design of my layout Z-ADM-JAN-8-2018. And my computer falls down! I needed 2 weeks and some helps to repair and now, I'm back. BUT I couldn't find my layout back. Unfortunatally, I never save it and distribute in the community (It wasn't ready yet!). Question : How to retreive my layout or is it cancelled for some reason? Thank you André- MBS-Controller : Official Forum Page
Hi, I try to use your step-by-step tutorial and I'm directly stopped : 1. The MBS_Controller_Template could not be found 2. - I start the empy project and the MBS_controller plugin - I am connected to "contrôleur de MBS V:1.0.0.5 - connected - Loading project - I let the scale to HO and I press OK - This results in a annel with 4 errors and 3 warnings and the project is not loaded - The status becomes "Not ready" ==> my question is : what am I doing wrong. Thank you in advance for helping. Regards André- Apple
Hi, I've currently the last professional version installed on my PC under Windows 10 and it works great. I also have an Ipad and I would like to know if it is possible to install the same version of 3D studio on this apple tablet and to share my projects. Thank you for your help André- adjusting terrain between tracks (New Users)
Hello, Finally, I found a "solution" : the lower tracks are fixed on the "lower panel"; the highter track are fixed to the "upper panel". Before adapting the terrain for the upper tracks, move the "lower panel" aside. So the "adjust terrain" will stop at the "upper panel"- adjusting terrain between tracks (New Users)
Hello Hubert, Thank you for the help. Yes, I have an hidden station (low level) and some tracks higher but at the same x & y displacement and also my central station in the middle. So, I tried putting the holes but, due to the size of the holes (min 50), these are too large and I need to add a plate just under the upper tracks to hide the holes (see picture). So, if you have a more efficient solution, I will follow it. - MBS-Controller : Official Forum Page
