Hi
In my present layout I am utilising, amongst others, model Fire Engine ladders 18 (by seehund). Whilst I can set each of the components manually to achieve the correct position for each component I cannot find out how to do this in my EV. Setting the out outriggers (stuetzen) is easy enough but I also need to set the following to specific points Drehen to 0.65, Neigung to 0.2 and ausfahren to 0.2. This then allows for everything to look right in the layout, see attached screenshot.
I have attached a test layout for the purpose of getting this right but thus far without any success. If anyone can point me in the right direction I would be most appreciative.
Kind regards
Pete
Fire engine test layout.mbp
following on from my initial request and in an effort to clarify the issue.
In properties for this model I need to be able to set Neigung to a 0.2 limit in forward motion, Drehen to 0.65 in forward motion and ausfahren to 0.2 also in forward motion. In the reverse operation all 3 need to reset to 0.
Clearly this can be done in the properties window but I need to be able to make this happen via my EV and as yet cannot see how this can be done. I feel it must be possible otherwise what is the point of having these elements move in the first place, setting them manually rather defeats the object somewhat.
All suggestions will be gratefully received
Pete
@220hotwheels,
You can do this in EV, but not with a block action. Only directly in Lua you can specify the limits. Don't be afraid about Lua. You only need a Skript-block element in Lua with the desired action. E.g.:
$("YY104 ERY Fire engine ").animations["Drehen"]:play(0, 1, 0, 0.65)
The syntax is:
$("Objectname")   -- is the object for the actions
.   -- means, next follows a property of the object
animations  -- the property animation is requestet
["Drehen"]   -- the "Drehen"-animation is requestet
:  -- introduce an action request
play  -- play the animation with max. 5 parameters (here 4: (0, 1, 0, 0.65) )
- parameter 1 = start position with 0 (=start), 1 (=end) or -1 (=actual)
- parameter 2 = direction. 1 = forward, -1 = backward
- parameter 3 = start position (between 0 and 0.9)
- parameter 4 = end position (between start position and 1)
- parameter 5 = tempo (1 = standard, e.g. 0.5 = half, 2=double)
To play the animations back to start position, you can use the normal animation-block in EV.
Here is the modified test layout:
Fire engine test layout2.mbp
Nice day
    Wolfgang
1 hour ago, prinz said:
220hotwheels,
The syntax is:
Nice day
    Wolfgang
Hi Wolfgang
Very many thanks for taking the trouble to provide me with a solution to my problem. It really is brilliant. Clearly the key is knowing, understanding and being able to execute Lua, something that I have no real understanding of. One element that I would like to change in your demo is the direction of rotation of the turntable owing to the fact that in my layout there are some old garages to the left of the fire engine so if this were to turn  in the opposite direction it would miss these.
All of that said I should also mention that a very good friend of mine has also provided me with a solution which also works perfectly and takes account of the garages. So now I have 2 solutions, both of which offer a different approach but nevertheless each has opened my eyes to alternative possibilities which will not only come in handy with this layout but will also help me greatly with other scenarios by enlarging my knowledge of how to approach certain problems, so once again very many thanks.
Kind regards
Pete
Hi Pete,
to save the old garages and change the direction of the turntable, you have to change the Skript for "Drehen":
$("YY104 ERY Fire engine ").animations["Drehen"]:play(1, -1, 0.65, 1)
The animation starts at position 1. Circular animations have for 0 and 1 normally the same position.
The animation should be executed backwards (-1)
The minimal position (!) is here 0.65 and the maximal position (!) is 1.
So the parameter description of my first answer was not correct, because parameter 3 and 4 are not start- and endposition, but minimal and maximal
value for the animation.
To bring the turntable to its initial position the animation (in EV-Block) has now start position actual, direction forward.
Here is the modified layout:
Nice day
    Wolfgang
Bearbeitet von prinz
correction of parameter 3 and 4
52 minutes ago, prinz said:
Hi Pete,
Nice day
    Wolfgang
Thanks Wolfgang. I did ponder on just what I might need to change but as I was unsure I didn't want to make a mess of things. Now I can add yet more information to the old memory banks.
Kind regards
Pete
