1785 -
Beiträge erstellt von hubert.visschedijk
vor 5 Stunden schrieb 220hotwheels:
Hi Hubert
Many thanks for that. I'll give it a try and yes I had renamed it as Fairmont suspension bridge.
Kind regards
Pete
Great !
vor 7 Stunden schrieb 220hotwheels:
draft elements can be uploaded so as I'm not prepared to remove your suspension bridge
Just ungroup the bridge if its one. Because the streets and the bridge are regular catalog models. Probebly you have saved it with a new name or so, as a group?
Have a try, it should go...
https://en.wikipedia.org/wiki/EMD_GP38
Fur fotos >>>> https://www.railpictures.net/showphotos.php
Und
https://en.wikipedia.org/wiki/EMD_GP38-2
"In addition, all 257 of Southern Railway's GP38-2s had Southern's "standard" high-short-hoods, which were later sold to Norfolk"
Und vielleicht....
https://de.wikipedia.org/wiki/Traction_Truck
Vorausplanen schadet nicht...
Viele grusse
vor 10 Stunden schrieb Wüstenfuchs:
Ich würde sagen ja, da die meisten anderen Wagen nicht so wirklich passen.
Ich werde in der Beschreibung erwähnen, dass es zu diesem Modell passt. Es kann auch nützlich sein, im Kipper zu erwähnen, dass es sich um ein amerikanisches Gerät handelt.
Viele grusse.
vor 5 Minuten schrieb 220hotwheels:
Having just spent an hour or so redoing my suspension bridge at scale 0.9 I was still finding it problematic getting the trucks to more through on both sides without catching the rear view mirrors and so I have removed my attempt and introduced yours, I hope you don't mind. It does look right and I simply have to redo some of the lower road and scenery, no real problem. If only real life was that simple!!
Kind regards
Pete
No problema at all. Thats sharing for !
i should have added streetlights....
vor 31 Minuten schrieb 220hotwheels:
just a bit silly!
who i am to judge...
vor 30 Minuten schrieb 220hotwheels:
just a bit silly
who i am to judge....
vor 11 Minuten schrieb 220hotwheels:
And I thought I had a twisted sense of humour!
Some sarcasm can be fun sometimes, when its mentioned in a healthy way and not intended to offend someone....
my 2 cents...
vor 4 Minuten schrieb 220hotwheels:
Could be interesting if two vehicles meet at similar points at the same time
You will need to EV there, allthough with the new V7 version that might resolve itself. At least... that is what i understood with what i have heard.
vor 4 Stunden schrieb 220hotwheels:
Just taken another look at my suspension bridge. I sent a truck with curtainsider trailer over and got a call from his boss to tell me that the poor guy had smashed his rear view mirrors, oops.
vor 4 Stunden schrieb 220hotwheels:I've now rescaled it from 0.8 to 0.85 and they now get through without damage, Phew.
good for the driver ! But who send the poor guy over the bridge in the first place ???
Be sure i will follow you updates when posted. Not to criticize, but because its a pleasure to look at, and enjoy, your layout !
(edited)
Perhaps you consider doing something special... leaving the bridge on its original scale and add a invisible switch on those spots where the pillars are. Every truck follows the switch position. As if hes deviating from the pillar.
Somewhat excessive perhaps to make, all in all with the layout, but it could be an funny option...
With kind regards,
vor einer Stunde schrieb Dad3353:
Naturally it takes quite some time to load, at first (I have but a rather modest PC...),
So with me as mine is modest too... but the result was worth it !
vor 2 Stunden schrieb arnyto:
Cool, thanks, if you have time can you do a "ballast" version or if we can upload the textur of your creation i can do several version and after i give to everyone here the different version i will create.
No.
Because they are ROTARY COAL WAGONS. And build only for the purpose of coal transport in the USA
Ballast wagons are other type of wagons, like on the picture that you have posted here.
With kind regards,
vor 6 Stunden schrieb 220hotwheels:
In your opinion should I post the amendment and if so how do I do this please.
Well, you should post it only when you want to. Just give a shout when you got some substancial alterations that you want to share.
You can be proud of the work and efford you have put into your layout untill now ! Nothing wrong in sharing ! Inspires !
But its in the same way as you did first. You can save it normally or save and share.
When you choose that option, it will upload again and will have the same ID number which was created on your first upload.
You could see it like this; The first time is upload, the rest is update. Same ID allways.
many greetings,
Yes I like your upgrade of the Golden Gate Bridge. I tried it on the Fairmont layout my only problem is that my original bridge had to be scaled down to 0.8 but still with the road scaled at 1. If I scale your version down to 0.8 then the road scale drops as well which I believe will cause a knock on problem in trying to connect the roads at both ends.
Yes, you cant scale it down as a whole model because of that.
I have seen that you scaled the bridge down first and then added the roads. My only objection to that is that a car might ( the trucks perhaps for sure) will touch the pillars. But on such a large layout, that is something I could live with... somehow.
Offcourse, a smaller version of such a nice bridge would be welcome. Who knows i may pick up the sketch again sometime. Not for now, for sure.
Many greetings.
Die Kohleanimation wurde hinzugefügt. Es ist der normale Weg, von oben nach unten.Viele grusse
The rock version is being made.
with kind regards
Am 12.8.2021 um 07:19 schrieb EASY:
das Modell wartet auf die Freigabe... und darauf (auch) auf schönen Anlagen zum Einsatz zu kommen...
EASYSchon freigegeben... in einen tag. .........
I found it... woow, gratz. So much detail and nice how you did the height diferences. You created some nice individual sceneries like that.
And, you have used the "golden gate" bridge. That was some work to get it alinhed for the roads. (it could need an update)
I made one for myself in the past also... 265C8BC5-5339-4E07-8169-6359A5385897
(even started to build a new one... but lost interest...)
If you call this one unfinished... cant wait to see it finished then. And if, upload it.
People love to see it and get inspired ! Id for one, need some EV lessons.. chinese for me....
Many greetings and gratz again !
from 09/09/2018
Heute morgen bin ich (zu) früh aufgewacht und habe ein bisschen gebastelt, nachdem ich den Post von @220hotwheels gelesen habe...
Sagen Sie mir, ob es hilfreich ist, dann werde ich @Neobitten, es im Katologen verfügbar zu machen.
F568DD94-EBD0-4339-8BBC-6C4BA923B61C
Pete,
Id like to see your layout when its done. Or even the way it is. Could you load it into the catolog ?
I dont mind if its not finished. You can always update it as you go.
What i do when i am building a layout is, is setting the grafics as low as possible. So no shades etc... That might help because i like large layouts aswell to create a real scene. I am not fond of "roundabout" layouts.
Since i saw the picture in your post, i crafted some sidings for the landstreets with 11 diferent textures to exchange.
These can be applied with the follow tool and also have a left and right version of it. So you can have dirt earth on one side and cobblestone on the other for example. For i recall, roads have sidings of stones or whatever, especially on the inner curve or busstops and crossroads.
Check it out;
vor 2 Stunden schrieb EASY:
Hallo @hubert.visschedijk,
Danke EASY, alles corrigiert !
vor einer Stunde schrieb EASY:
Und CSX und Burlington Northern im LOD_2 hat auch eine probleme...
Hubert - Modellbau
in Modelle
Geschrieben · Bearbeitet von hubert.visschedijk
Hallo alle,
Mal ein anfang prepariert mit die unterteilen die ich schon habe von EMD SD70Ace
Welchen Unterschied würde ein Kupplungsdrehpunkt machen ... vielleicht für einen V8?
