I have created a video introduction to MBS (3D Train Studio) and will be adding more episodes to the series in the following months.
here is the URL for the first episode.
Hello Curt,
it's an excellent tutorial video - also very good understandable for German users with rudimentary Englsh skills.
Congratulation !!! (y)
Many greetings
Bearbeitet von BahnLand
Hello Curt,
after watching your first tutorial, I'd like to inform you about a neat copying trick in the MBS:
Select an item, hold down the ALT key and then drag the selected item away a bit. You'll find that you don't drag the original item, but instead a copy of that item.
Better still: You can do this with groups too. You can for instance build half an oval, block-select it, drag a copy out (by holding down the ALT key), spin the copied block 180° and bring it close to the original half to make it snap in. The result is a complete and joined up oval.
Here's a short video (without sound) demonstrating the procedure:
ALT key copying in MBS
Whenever the gismo disappears, I'm holding down the ALT key.
Bearbeitet von Goetz
Vielen Dank für Ihre Informationen und Anregungen. Ich werde es in einer kommenden Episode der video hinzufügen.
Ihre Hilfe ist sehr willkommen
Curtis
2nd part of series has been uploaded.
Bearbeitet von Curt84328
Hi Curt,
... well done !
.... most time i do not need the sound to understand what to do...
...  in German we say "Bilder sagen mehr als tausend Worte" (Pictures say more than a thousand words)... this is true for your videos
  • 2 Monate später...
The third episode of 3D Train Studio is being uploaded,
this one is a little long, and had to be redone so it is a bit late.
here is the layout from Episode 3,
Episode3.mbp
  • 1 Monat später...
Is ther more locomotives than what shoes up in the program
